Question about Rain Bird 4 Station Single Program Sprinkler Timer ISA304
We have a ISA 304 Series Sprinkler Timer. All station but the 1st one work great. Station 1 has never woked can you help
How stop sprinklers from starting over
You only program the first zone to turn on at a specific time. The rest of the zones go in sequence.
Aug 22, 2014 | Orbit 6 Station Indoor Dual Program...
"my orbit easy dial 6 station quit working in auto
Does it work manually? If so, which is rare and almost unheard of I would replace the timer. You can't buy a less expensive timer $20 for a 4 station. Which explains why it is not working. If it doesn't work make sure it is plugged in and outlet has power.
Aug 11, 2013 | Orbit Irrigation 57856 6 Station Easy Dial...
4 station timer help
Copy following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Most major brands are linked here, including manuals for each.
Some brands such as yardworks, etc, repackage other brands and have no online support or clear resolution for warranty claim.
Open link, then add a comment with brand and model and voltage so expert can access same manual.
Replace battery. Reset timer. Check if unit is getting power. Check if outlet has correct polarity. Are some basic troubleshoot steps.
Most timers have 1 year limited warranty, and timer that came with used house may no longer be functioning. Or the sprinkler hear has gone bad.
For replacement, I think Intermatic mechanical sprinkler timers are better value than digital timers, since the mechanicals have repair motors and trippers and can last 25 years.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Add a comment for more information on timers.
May 22, 2013 | Hardware & Accessories
Timer programming help
Maybe the sprinkler head is not advancing.
May 22, 2013 | Orbit Hardware & Accessories
Each station opens valve #1
Sounds like you have a wire in the MV pin without a Master Valve.
Oct 19, 2012 | Rainbird Rain Bird Esp-6tm Sprinkler Timer
I just got an Orbit 4 Station Sprinkler Timer with Easy Dial from the landscaper who did my sprinkler system a week ago, he set the timing at 6:30 AM I changed it to 5:45 and SET it and now its running...
You don't program each station. You only program one start time that begins the cycle that consists of the three stations.
Remove all start times but the first one and make that 5:45.
Set the station times to whatever you want, 12 minutes.
At 5:45, station 1 starts.
at 5:57, station 1 shuts off, station 2 starts.
at 6:09, station 2 shuts and station 3 starts.
at 6:21, station 3 shuts.
Your FixYa Texpert,
Gary
Aug 26, 2011 | Garden
This is a sprinkler timer: Irri-Trol MC plus SERIES CONTROLLERS. When the timer starts, it will go smoothly from stations 1 through 5. At station 5, the timer goes off because a trip switch inside...
Move the wire from Station 5 terminal to Station 6 terminal, remove time from Station 5 and put time on Station 6 and see if that helps. It sounds like the timer is tripping a circuit breaker and normally they don't draw that much power. If the problem continues on Station 6, replace the solenoid to the valve for that station. Even so, I have never heard of a timer tripping a breaker.
Your FixYa Texpert,
Gary
Aug 20, 2011 | Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Sprinkler station drives another station by mistake
change the control valve for line 2. the coil is not pulling the plunger all the way in.
Apr 30, 2009 | Nelson SoloRain Irritrol Valve Adapter
Rain Bird 4 Station Single Program Sprinkler Timer ISA304 Logo
93 people viewed this question
Top Rain Bird Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Rain Bird Hardware and Accessory Expert? Answer questions, earn points and help others
