Question about HP Photosmart C4580 All-in-One - InkJet Printer
Printer wil not print because it says "out of paper" - but there is paper there - it just will not feed - I hear it trying to do so - but it does not work - I see nothing stuck in there - HP Photosmart C4280 all-in-one
  • clcoh11 Aug 27, 2010
    do not think so - the printer is only 14 months old and gets very, very little use - paddles do NOT show any sign of wear - printing just stopped suddenly
  • HP Master
  • 17,130 Answers
There is a optocoupler that detect the presence of paper by IR sensor. So if there is dirt on it , it ispossible to have this message on to the display.
remove off paper and do a good cleaning, the sensor is fixed just near the outlet of the paper to indicate when the last bit crosses over. Clean the tiny sensor holes and check.
If not it is possible that the sensor is faulty and must be replaced. You can open board to check the signal to see if the detection is showing a reading, but do this only if you are familiar to open up the mother board.
Posted on Aug 28, 2010
  • 10,319 Answers
The feeder paddle is worn. It has rubber flaps to move (advance) the paper. Replacements maybe still around through hp.com
Posted on Aug 27, 2010
Printer wil not feed paper in -keeps trying but paper will not move in.
Hi Jamieos,
Turn the printer off and on.Solved?
Turn the printer off and disconnect from PC.Unplug from power.Reboot the PC.
Remove the papers from the feed tray and look through the paper path for any obstructions.
Load the print papers and make sure they are correctly aligned on the feed tray.
Cear any print queues on your PC.
Connect everything now and start the PC.
Try printing.
Hope this helps.Thanks!
Please rate this answer.
Dec 14, 2011 | Epson Stylus 1400 InkJet Photo Printer
My Konica Minolta bizhub C250 seems prints about every 10th page crinkled and crooked. I can hear it going through the machine and crushing a crease in the paper as it prints. The printed also seems to...
The paper may not be feeding straight out of the paper tray due to poor stacking of the paper in the paper cassette. try another paper tray or check the paper in the paper tray for folded over papers usually near the bottom. Also try feeding paper from the hand feed tray on the left side. This uses a different paper path.
Dec 07, 2010 | Konica Minolta bizhub C250 All-In-One...
My printer is saying 'no paper feed' when there is clearly paper. The printer is not gripping the paper so it could print.
THe first thing to do would be to clean the pick up roller/s. If you can not reach them by hand, use a sheet of fine sand paper. put the sand paper in the paper tray so the gritty side will contact the feed roller. Then hold the paper in place while exicuting a test print. You wil get a jam, or papaer empty indicator. now do it again, and then one more time. Now remove the sand paper and use a damp thin cloth. make sure this is secured and will not be pulled into the machine. Now one more time run a test page. Now you should be good to go. If this did not solve the feed problem your feed rollers need to be replaced, or you have a paper present sensor problem. This could take some disassembly so let's try the easy stuff first.
Oct 06, 2010 | Brother MFC255CW All-in-One InkJet Printer
Paper won't feed up to print
Try using Windex and a lint free cloth(not paper) on the feed rollers. The rollers may be glased due to age or use. If that does not work, call a tech.
Jun 25, 2010 | Konica Minolta magicolor 2400 Laser...
Paper is getting stucked in the canon printer
Just clean the print head and also ensure that the paper is placed proprely and no other piece of the paper is inside it . Most probably cleaning the print head willsove yur problem
Thank U
Please rate my solution as it wil cost u just one click
Nov 05, 2009 | Electronics - Others
Paper Jamming when trying to copy or print
please check after you load paper on the paper tray and push it into the machine, should hear a click sound, if you don't hear that sound, that means you need to buy a new printer and that's no way to fix.
If you are able to hear a click, then please try to clean up your printer and check all paper loading rolls. if so, please replace it.
May 21, 2009 | Brother MFC 7420 All-In-One Laser Printer
Quiken 2009 will not print on HP C6180
Objects or paper blocking printhead or paper feed path.
Feb 11, 2009 | HP Photosmart C6180 All-In-One InkJet...
My printer no longer feeds in Epson Premium Glossy paper S041624
Try to clean the paper pick rollers with a cloth, dam it with little water and try to hange the paper settings by going into printer preferances.
Regards,  raj_p5983
Jan 20, 2009 | Epson Stylus Color 1160 InkJet Printer
Epson Photo RX600 error messages
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Open Questions:
See all HP Photosmart C4580 All-in-One - InkJet Printer Questions
HP Photosmart C4580 All-in-One -  InkJet Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
