Question about Maytag Atlantis MDE7400AY Electric Dryer
Circuit breaker keeps tripping - Maytag Atlantis MDE7400AY Electric Dryer
  • Maytag Master
  • 43,501 Answers
If the breaker keeps tripping then there is a short somewhere.. the first place I would look is the heating element probably broke...
heatman101
Posted on Aug 29, 2010
2 Suggested Answers
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
No lights upstaires circuit breaker keeps tripping
Jan 2013
1) Move wire to another same-size circuit breaker to eliminate bad circuit breaker as suspect.
Do NOT increase size of breaker or it will cause fire.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html
2) Put hand on each appliance and outlet to see which ones are warm. Outlet should never be warm or hot. Replace outlet. Inspect wires for loose and burned connections.
3) If the breaker is good, then add up total watts being used by checking watt rating on each device. 100 watt light bulb is 100 watts. Big screen TV has a label that shows 300 to 500 watts. Computer has label. Space heater has label showing 1500 watts. Iron has a watt rating label. Take total watts and divide by 110Volts and this will give amp load. Total watts used = 2000 and then divide 2000 by 110 volts = 18.8 amps
Compare amp load with circuit breaker.
20 amp circuit breaker has 80% safe maximum, or 16 amps.
If amp load is 18.8 amps, then 20 amp breaker is starting to get hot, and weak breaker will start tripping.
If amp load is 18.8 amps, and breaker is 15 amps, then you are overloaded and breaker is feeling the heat, and tripping because of heat.
Solution is to reduce amp load.
4) If you have short circuit, that can also trip breaker.
Unplug everything and then plug things back in slowly to see which plug or appliance is causing the problem.
Jan 18, 2013 | Electrical Supplies
Tip
Circuit Breaker Keeps Tripping
Your circuit breaker keeps tripping and you are wondering why it would do that. There actually can be many things that can cause a circuit breaker to trip, or shut off. I will give you some reasons why circuit breakers trip and also some circuit breaker troubleshooting tips.
The first thing to remember about a circuit breaker is that they are first and foremost a safety device. The protection provided by the circuit breaker is also two fold. The circuit breaker will protect against overcurrent, or in other words, it will keep you from melting down the wires by placing too high of a load on any circuit. This would cause the wires to overheat and start a fire.
The other way a circuit breaker protects you is that the circuit breaker senses very quickly if there is current flowing to the ground with out it going through a load. This means that there is a shock hazard or a fire hazard. The circuit breaker will interrupt the current and shut off to prevent damage from happening.
If your circuit breaker is tripping off then you need to find out why this is happening. By eliminating the load on the circuit you can start to narrow down the possibilities. If there are a number of things plugged into the circuit then unplug something till it will stay on.If you can get the load low enough so that the circuit breaker stays on then you are okay and just need to spread the load out over a couple of circuits to prevent the overloading.
If you cannot stop the circuit breaker from tripping, unplug loads until you narrow the problem down to one thing. Once you narrow it down to one thing that is tripping the circuit breaker then you can find out why the load is tripping the circuit breaker.
Now if the load that is still plugged in is an appliance like a washing machine, then you need to find out if the cause of the tripping is the motor or if it is something like a wire that is rubbed through and is shorting out. If it is the motor the circuit breaker will often trip right when the motor goes to start up.
If the circuit breaker trips immediately when power is applied then you probably have a bad wire or connection. Poor connections are common in appliances such as an oven or a dryer where high amounts of current can be pulled at one time and the heat will make the connection get hot and eventually fail.
There are so many different possibilities for circuit breakers tripping that it is impossible to cover them all. There is one tool that will make the detective work of finding a short or problem much easier.This tool is called an "OHM" meter. One of these can be purchased at most any hardware or electrical store. Many big box stores and even a Wal-Mart also have them. There are many very inexpensive models available.
By using an OHM meter you can check the resistance of a circuit. The idea is that if a circuit has NO resistance to ground then it is bad and the electric can flow to the ground unhindered. This is a dangerous situation and must be corrected. In motors the flow of current between phases with no resistance, is also a reason why a circuit breaker will trip.
Above all remember that you need to verify and make sure that all electric is shut off to any piece of equipment that you are working on. Isolating and finding electrical problems can be very time consuming and frustrating. It will take time and patience to methodically eliminate the possible causes of a circuit breaker that keeps on tripping or a circuit breaker that will not reset. Through careful checking you can one by one eliminate the possibilities and find the cause of your circuit breaker not staying on.
on Oct 03, 2010 | Hammering
Model 4001-ov trips the circuit breaker.
Assuming you have Paragon 4001 40 amp 120Volt timer
By-pass the timer so only pool pump is connected to breaker.
To do this, move wire from terminal 2 and connect to terminal 1.
If breaker no longer trips, then replace timer with Intermatic T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Crossover wiring: Paragon terminal 1 goes to Intermatic terminal 1.
Paragon terminal 2 to Intermatic terminal 2.
Paragon terminal 3 to Intermatic terminal A
If breaker keeps tripping after bypassing timer, then tighten wires on circuit breaker and test again.
If breaker keeps tripping, then move wires to another same-size breaker.
Breakers trip when they sense overheating.
If motor is causing problem, you might need electrician to track down source of overheating.
Jun 19, 2012 | Paragon 4001-0G Defrost Timer
I have a square D breaker with shunt trip. The breaker keeps tripping so how do I check the breaker?
A shunt trip breaker operation.
It works just like a normal circuit breaker with one additional function. A shunt-trip breaker also has a built-in magnetic coil that can be energized externally to trip the breaker.
So what is wired to the shunt that is not letting the breaker reset?
Read more: http://wiki.answers.com/Q/How_does_a_shunt_trip_breaker_work#ixzz1EXNCP5r0
Feb 20, 2011 | Square D Qob120 Circuit Breaker With Shunt...
SL24J30 KILLING CIRCUIT BREAKER
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
heatman101
Jun 24, 2010 | Friedrich SL24J30 Air Conditioner
Keeps tripping the breaker
What size breaker?
as long as there are no other appliances or anything on the circuit a 15 amp breaker will do...if you have alot of other items on that same circuit you either need a larger breaker, or use a different circuit all together
Mar 31, 2010 | Gold Medal 2656 Ultra Popcorn Maker
The Lights circuit breaker keeps trips without load
try a new breaker, they do wear out over time
Feb 08, 2010 | Electrical Supplies
Dryer trips circuit breaker
heatman101
Nov 21, 2009 | Kenmore 63942 Dryer
15 Amp circuit breaker keeps on tripping , as as
breaker tripping right of way means bad breaker or dead short. which means something has burned out or is wired incorrectly
May 13, 2009 | Heating & Cooling
Whirlpool electric dryer keeps tripping main circuit breaker
Feb 02, 2008 | Whirlpool LER5636P Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
186 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
