Question about Acer Aspire One AOD150-1920 Netbook
Touch pad is not working and system when it starts up it is OK but shortly afetrwards it saturates
  • 82 Answers
Try installing the latest driver if that fails, you might need to pry off the bezel and clean the toucpad there might be some dirt that got stuck in there and causing it to press on the touchpad
Posted on Aug 27, 2010
Audi a6 quattro brake warning
This is my take on the problem. The factory setting for the brake travel at the caliper is what triggers the warning, just because there is pad left (not to thr rivets) does not mean the pads are ok .
I would try backing the travel on the caliper to the far open pisition then reset the computer start the car do not touch the brake pedel
the light should be out. if this works replace the pads.
Nov 20, 2013 | Cars & Trucks
THE TOUCH PAD ON THE OVEN DOES NOT WORK
If the interlock door switches are in line and OK, change the touch pad as there is a shorted contact.
Contact the manufacturer for details of a dealer that will sell spares.
Hope that helps.
Nov 15, 2010 | Microwave Ovens
The touch pad is not working and also the system starts up Ok but after a while it saturates and would accect any commands
thats the freeze up that they call, i suggest lower the contrast so the battery will have smooth capacity then disable screensaver, all update make it manual, http://www.buzzillions.com/reviews/acer-aspire-one-aod150-1920-10-1-netbook-reviews <--this is the review of that however if you will lessen the auto sched of this netbook the freeze up will disappear.
Aug 27, 2010 | Acer Aspire One AOD150-1920 Netbook
Timer starts beeping and flashes F1
Hello there:
if this is the newer style oven then follow the gujide i have provided below and if it is a older style follow the guide i have provided below the first one ok
newer style
F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
older style
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
Jul 23, 2010 | Jenn-Air JGW8130A Electric Single Oven
Display shows E0 F2 after pressing start and cancel at same time. No other buttons work. Stovetop still works.
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 14, 2010 | Whirlpool GY398LXPS Electric Kitchen Range
Oven is displaying f1-8 error code what is it
F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
May 04, 2010 | Jenn-Air SVE47100 Slide-In Electric...
My touch pad does nothing
start in safe mode and see if it works, if not, try to uninstall and re-install the mouse drivers ( could be a conflict) if driver re-installation fails, do system restore to a date when the touch was ok( you could have been hit by a virus). if still no luck, check touch pad hardware> means you have to open unit. check the touch pad to motherboard interface( could be loose).
Regards
Feb 24, 2010 | Gateway Computers & Internet
My g2 microven touch pad will not work, everything else works. I unplugged it and plugged back in ,shows touch error high fail 255 177 and low fail 246 0
Hello there
looks like you have a touch pad that has shorted out and is in need of replacement
please go to www.whirlpool.com and they have a technical help section ok.
best regards mike
Jul 31, 2009 | Whirlpool Microwave Ovens
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Error message and alarm
These are the fault codes for your unit
or
Hope this helps, Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Maytag MGR5870 Gas Kitchen Range
Acer Aspire One AOD150-1920 Netbook Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
