Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Leveling the machine
We just moved and need to level the machine. It leans.
    Genius:
  • 1,073 Answers
Adjust the bottom leveling legs on the machine
Posted on May 07, 2008
Where is the balance sensor located on my Kenmore Elite Oasis washer
Hello.
Top loading washing machines can emit loud noises and vibrations if they are not properly balanced. Imbalanced machines are the result of large loads of clothing that rock the machine causing one or more of the feet to rise off of the floor. Front loading washing machines do not have this problem because there is no side-to-side motion. Kenmore top loading washing machines have self-leveling feet on the rear of the machine and adjustable feet on the front of the machine.
1 plug the washing machine's power cord from the electrical socket. Pull the washer away from the wall, or out of the laundry closet, so that it is easily accessible.
2 rasp the top back of the washer on both sides and tilt it forward until the back feet are off of the ground by 4 inches. Lower the washer gently back to the ground. This maneuver, adjusts the self-leveling rear washer feet so that they are fully extended. You may need the assistance of another person to do this.
3 lace a level on top of the washer near the front edge. Look for the air bubble in the level to determine which side of the washer is out of balance. The side that the bubble leans toward is the side the needs to be raised.
4 Move the level so that it is positioned along the side edge of the washer and check to see if it is level from front to back. If it is level, move it to the other side of the washer and see if it is level.
5 Lift up on the front of the washer and insert a wooden block or brick under the front bottom edge.
6 Crouch down on the floor near the front foot that needs to be raised. Use your fingers to twist the threaded foot clockwise to retract the foot and counterclockwise to extend the foot further. If necessary, adjust the other front foot as well using the same method.
7 Lift up on the top of the washer and slide the block out from under it. Place the level on top of the washer to check that it is level. If the washer is not level, replace the block and continue adjusting the feet until the air bubble is centered in the level.
8 Crouch down on the floor near the front of the washer and use a 14 mm wrench to twist the metal nut on each front foot counterclockwise. Twist each nut until each is tight against the washer and will no longer move.
9 Plug the washer's electrical cord back into the wall.
And the problem will be solve.
Thanks.
Nov 13, 2011 | Washing Machines
Where is the balance sensor located on a Kenmore Elite Oasis washer
Hello.
Below are instruction on how to solve the problem of the washer.
9 lug the washer's electrical cord back into the wall.
Thanks.
My front load washer keeps going off balance. Even with small loads. I have leveled the washer but I'm not sure what else to try.
Material needed to carry out the function.
  • Level,Another person,Wooden block or brick,14 mm wrench
  1. Unplug the washing machine's power cord from the electrical socket. Pull the washer away from the wall, or out of the laundry closet, so that it is easily accessible.
  2. Grasp the top back of the washer on both sides and tilt it forward until the back feet are off of the ground by 4 inches. Lower the washer gently back to the ground. This maneuver, adjusts the self-leveling rear washer feet so that they are fully extended. You may need the assistance of another person to do this.
  3. Place a level on top of the washer near the front edge. Look for the air bubble in the level to determine which side of the washer is out of balance. The side that the bubble leans toward is the side the needs to be raised.
  4. Move the level so that it is positioned along the side edge of the washer and check to see if it is level from front to back. If it is level, move it to the other side of the washer and see if it is level.
  5. Lift up on the front of the washer and insert a wooden block or brick under the front bottom edge.
  6. Crouch down on the floor near the front foot that needs to be raised. Use your fingers to twist the threaded foot clockwise to retract the foot and counterclockwise to extend the foot further. If necessary, adjust the other front foot as well using the same method.
  7. Lift up on the top of the washer and slide the block out from under it. Place the level on top of the washer to check that it is level. If the washer is not level, replace the block and continue adjusting the feet until the air bubble is centered in the level.
  8. Crouch down on the floor near the front of the washer and use a 14 mm wrench to twist the metal nut on each front foot counterclockwise. Twist each nut until each is tight against the washer and will no longer move.
  9. Plug the washer's electrical cord back into the wall.
Hope this help?.
Thanks for visiting.
Oct 17, 2010 | General Electric WCVH6800J Front Load...
Sides vibrate during spin causing a lot of noise and machine moves. could it be out of balance?
1- Clothes are not balance inside the tube. Try to rebalance the clothes when it happens. It usually happens when towers leaning on on side when water level selector not set appropriately. 2- Try to level the washer by adjusting the leg screws at the bottom of the washer. 3- It make a lot of noise since the whole washer moving against the floor. When it spin only the tube then it won't be like that.
Jan 02, 2010 | Kenmore HE3T Washer
I have a Kenmore top loading washing machine model 92529110. My wife has been noticing that the tub leans toward the front causing the water to hit the back edge of the tub instead of running straight into...
The machine needs to be leveled. Unscrew the front legs until the machine is level. If there isn't enough screw, or if your floor is really uneven, put a board under the front legs. After you get the front level, lean the machine toward you, tilting it front, until the back feet are about 3 inches off the floor. Let the machine drop. This will set the back legs into position. They are self leveling.
Nov 14, 2009 | Kenmore Washing Machines
Maytag Ensigna MTW5630TQ1 water splashes out underneath the right front corner as the washer starts to spin out between the wash and rinse cycles. It's only an ounce or 2 now and it just started, warranty...
Reduce the wash load, and also reduce the water intake level. Make sure you distribute the cloths evenly around the tank. See if that helps.
Make sure the machine is level.
When you open the lid, move the agitator from side to side and front to back. Make sure it springs back to centre when you let go. If it doesnt, or it leans to the front, then you need to service the suspension.
Good luck
Ash
Oct 22, 2009 | Maytag Washing Machines
WASHING MACHINE OVERFILLING
Suspecting the water level switch is the first step since this device controls starting operations. There is also a possiblity that the water level pressure hose has come off the tub. Make sure this plastic line is attached before replacing the level switch.
Jan 13, 2008 | Washing Machines
Leveling a washer tub how to do so
first get a level. second, some have self leveling rear legs, just lean the machine forward and set down slowly. the rear legs are now level. if you dont have self leveling rear legs, the legs screw in, so just screw them in or out as well as the front legs untl it appears level by eye. now place the level on the washer. check it front to back and side to side. try rocking the machine to see if there is any movement. if there is adjust the legso it stops rocking, all the while keeping an eye on the level
Sep 27, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
