Watches Logo
Posted on Aug 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there only one size fossil watch link. Either too big or too small with the links it came with.
Janelle Schoonover
Level 3:
  • Master 842 Answers
  • Posted on Aug 28, 2010
Janelle Schoonover
Master
Level 3:
Answers
842
Questions
Helped
457503
Points
2634
Thanks for contacting FixYa.
Yes, each watch has only the one size link that is on the watch. Sorry.
Best regards. Jewel
Where can I get extra links for the band?
Moto 360 - Extra links for metal watch band - Motorola Support
https://motorola-global-portal.custhelp.com/app/.../prod.../2815,9141
Your metal watch band can be expanded by adding links. The small gray envelope inside the watch box (see image below) contains four extra metal links.
Order Links & Bands - Fossil
https://www.fossil.com/us/en/.../order-links-and-bands.html
Fossil GroupOrdering Links & Bands (U.S.). Order Links. Extra links can be ordered with a U.S. issued credit or debit card by calling the Metro Service Center at ...
Parts Archives - Citizen Watch - English (US)
Dec 25, 2015 • Watches
3helpful
I have a sport watch fossil CH2470. the second hand is not moving, stuck on 12, but everything else works. how do i fix this?
Your watch is Chronograph watch and the big centre seconds hand is for chronograph function only - not day to day seconds counting. Check the small dials and you will see that the small seconds hand is already counting seconds- this small one is seconds counter. To engage chrono hand push the upper push button once. To stop it - push the same button again. to return to zero- push lower button. For users manual use this link: http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html Rate me, please.
I need to order links for this watch its to small
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-orderlinks.html (paste this link into your search engine) and you will be able to order links for your watch.
If you want only 2, then you only pay postage!
I've lost two of the little crystals on my fossil watch band. How do I replace them?
Link
Hi cdtburks,
Please try browsing the link above to contact the Authorized Dealer of Fossil.
Thank you.
4helpful
Watch Too Small
Extra links for your Fossil watch can be ordered by calling Metro Service Center at (800) 842-8621.
For all watches we offer up to two additional links. There is a $4 shipping & handling charge for all link orders. If more than two links are needed, you will be charged $3 for each additional link requested.
Please note that each additional link adds approximately  inch to the watchband. Link quantities are limited and are not guaranteed to be in stock.
Fossil ES1443, adding a link.
you can add links to this model , i would email fossil to and check if you can order some spare links.
[email protected].
the links have pins located on theside of the barcelet these can be pushed out.
Kind regards
Rob
Sep 17, 2017 • Watches
1helpful
Link pins for a womens Fossil watch
The only place you can get them is at a watchrepair. Sometimes I have found wierd sized link holes and have had to make my own pins. I just take a small nail and file it to the size I need. If you have a dremmil tool with a sandpaper attachment it is so much easier! Take a nail that is a little bit longer than the link is and sand down in a slow graduating cone shape, make sure to top of the nail is a little bit wider than the hole on the top of the link. Once you have that , put the smaller end in the link , line up the other link so that the pin goes into both links , and then tap it in. The pin should go into the bottom of the links. It might be good to do this on a piece of wood so that if the pin goes a little through the bottom, you don't damage anything. Try to make the pin as tight as you can, and than file (or dremmil) the top and bottom to the links size. If you still have problems please let me know, and maybe I can help you further. Good luck!!!!!
I have a fossil watch...how can i remove a link(stainless steel band
a jeweler or the fossil store would have the right tools to do the job, but you basically just need something strong and thin enough to fit in the hole where the pin is. You will need a small hammer or something that isn't too big but has enough weight and control to tap the pin out. After that you pretty much just take the link out and reconnect the separated ones.
Apr 13, 2008 • Watches
1helpful
How to adjust band
My best suggestion to you is to take it to a Fossil store (they will do it for free!), or go to a jewelry or department store (Dillards, Foleys) to get it sized right.
The problem with doing it yourself is if you do not have the correct tools you can scratch the watch or bend the pins easilly. Especially with the black band like you have.
If you go to a jewelry repair shop they will charge you. I have seen them charge anywhere from $2.00 to $15.00. Unlike Fossil or a few other big department stores.
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
