Question about Norelco Reflex 5841 XL Electric Shaver
Red LED stays on
Bottom Red LED stays on constantly. Green LEDs no longer show up even after charging for a long period. Runs with or without plugging in
  • 33 Answers
Sounds like the rechargeable batteries are aged out, and no longer able to develop a full charge, and soon will be needing replacement.
A repair center might likely do it for you for a fee, but see "Self Repair" on site:
http://www.fixya.com/support/t961386-change_battery_in_norelco_5841xl_razor
Good Luck GB_C
Posted on Nov 04, 2009
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
What would be the probable cause of a sony vaio fs830/w of starting up & the 3 green leds on top stayed lit
You were FORMATTING it? Meaning... you were erasing the operating system? If that's the case, then... you have no operating system and the computer cannot boot up because it has no operating system to boot into.
Jul 30, 2014 | Sony VAIO VGN-FS830/W Notebook
Razor e200
Hi, check all the connections are clean. It could be the charger is done but some batteries when they get left for a long period without charge they won't take a charge any more. Disconnect from power supply before attempting any inspection. Check the wheels are turning freely and not binding. Then last of all the motor may have to be checked.
Apr 21, 2014 | Toys
When charging my light stays red does that mean its charging
Some chargers have 2 LEDs (lights), some have one. Both chargers have an LED that is red (or orange) when the charger is charging a battery and turns green when the battery is charged and the charger has dropped back to trickle charge mode or off.
On the charger with two LEDs , the extra LED is normally red to indicate the mains power is connected.
Sep 10, 2013 | Razor MX500 Dirt Rocket
Quadra 7865xl won't start unless plugged into an outlet. Sometimes have to press the button many times to start. Charge the battery to full (all LEDs green), start & unplug cord, will run for over an...
It sounds like you have an intermittent connection. When an internal power connection is lost, it will cause the charge indicator to indicate discharged. Check your solder connections, particularly the solder connections that hold the batteries in place
Jun 07, 2017 | Norelco Quadra 6885 XL Electric Shaver
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
My 53WUX10BA Red Power light will not go out
will not power up it worked fine then last week it stoped turning on it just turns off as soon as i turn it on
Oct 29, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Same Problem
Hello, it was:
■ Charging LEDCharging LED
 Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Or if the red LED remains on without turning green could mean a bad battery that no longer charges to 100% - get a new battery. Hope this helps
Jun 05, 2008 | Samsung Digimax i5 Digital Camera
Norelco Reflex 5841 XL Electric Shaver Logo
143 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
