Question about Acer Aspire One AOD150-1920 Netbook
The touch pad is not working and also the system starts up Ok but after a while it saturates and would accect any commands
    Problem Solver:
  • 14 Answers
Thats the freeze up that they call, i suggest lower the contrast so the battery will have smooth capacity then disable screensaver, all update make it manual, http://www.buzzillions.com/reviews/acer-aspire-one-aod150-1920-10-1-netbook-reviews <--this is the review of that however if you will lessen the auto sched of this netbook the freeze up will disappear.
Posted on Aug 27, 2010
Touch pad not working
Hi
Maybe you accidentally hit lock key of your touch pad. Just press FN key + F7 key (key logo for touch pad).
Or run the SYSTEM RESTORE, Go to START, Choose ACCESSORIES, choose SYSTEM TOOLS, choose SYSTEM RESTORE and then choose PREVIOUS RESTORE DATE that your touch pad is working fine. If not, use the other restore dates if necessary.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 26, 2011 | Computers & Internet
Touch pad is not working and system when it starts up it is OK but shortly afetrwards it saturates
try installing the latest driver if that fails, you might need to pry off the bezel and clean the toucpad there might be some dirt that got stuck in there and causing it to press on the touchpad
Aug 27, 2010 | Acer Aspire One AOD150-1920 Netbook
Go to Start and then type MSCONFIG and click Ok then go to Start and enable all Start-up and resart the system......Hope it works...Goodluck!
Aug 02, 2010 | Computers & Internet
My touch pad does nothing
start in safe mode and see if it works, if not, try to uninstall and re-install the mouse drivers ( could be a conflict) if driver re-installation fails, do system restore to a date when the touch was ok( you could have been hit by a virus). if still no luck, check touch pad hardware> means you have to open unit. check the touch pad to motherboard interface( could be loose).
Regards
Feb 24, 2010 | Gateway Computers & Internet
Acer 5517 mouse pad does not work. is it just a
First you should check if the button that enables and disables your touch pad is on. It's the button left to the power button.
Feb 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
My r60 model upper tochpad keys not working
Lets see if the Lenovo computers are alike, since I have a T60 version...
Lets start by going to the: -> START button click on the Control Panel -> click on MOUSE -> click on ULTRANAV tab -> there will be a check mark to Enable the Touch Pad Check off the Touch Pad and click on APPLY to save and OK to back out.
Voila, your Touch pad should be working then.
Good Luck.
Sep 18, 2009 | Lenovo ThinkPad R60 Notebook
I cannot enable the touchpad settings.
Hi there...
First of all has the touch pad ever worked?
Lets give this a try, go to the START button and left click, look for the CONTROL PANEL and double click on it.
When the Control Panel opens look for the MOUSE and double click to open page, on the tabs look for ULTRANAV, you should see a check mark box, ensure that there is a check mark under the Enable Touch Pad, hit the APPLY and OK.
Voila, your touch pad should start working.
Aug 29, 2009 | IBM ThinkPad R40 2722 Notebook
Whilst typing the cursor moves to another part of the document
If your laptop has the option too you can turn off touch pad through a switch above the touch pad.
If you can't find this, or you don't have one, simply go to the run command and type in devmgmt.msc, ok.
Once in the device manager go "Mice and Other Pointing Devices"
look for your touchpad, right click on it and select disable.
Please note, some laptops wont let you disable to the touchpad, mine wont, but mine has an on and off key.
ON/OFF Key
Touch Pad On
Touch Pad Off
This will keep the mouse from moving whole you type, but I suggest you get a regular mouse, especially if you have to disable the device with the Device manager.
Jan 05, 2009 | Computers & Internet
Toshiba Laptop "Enter" and touch pad not working
This screen should have a 30 second count down, then start Windows normally. If yours doesn't do this, then she may have keyed the automated recovery and interrupter it causing an operating system error or glitch. If this is the case you will need to run a system repair with your recovery or operating system disc. If it does start Windows after the count down, then run a system restore. One of these will take care of your problem. Also, there is no locking command for the touch pad or enter key.
Aug 01, 2008 | Computers & Internet
Ink build up under cartridge
if u look at the back of the unit there is a back door which u can take out .
or u can open the front access door [ from where u insert the cartridge ] , in case u r not able to clean it from there .
u might need to get the unit serviced ,for that either contact HP customer care at 1800 474 6836 or on-site Repair Center at 800-633-3600.
Thanks
May 22, 2008 | HP Officejet 5610 All-In-One InkJet...
Acer Aspire One AOD150-1920 Netbook Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
