posted by lurell on May 06, 2008
i can receive faxes but can;t fax and i the maybe the memory is full
Solution #1
posted on May 28, 2008
It is more likely that there is a setting or error... are you receiving any error msges or alerts when you try to fax out?
Just in case here are the steps to turn off fax memory
- Follow these directions to turn off the fax memory.
- Press Menu/Set.
- Press the up or down navigation key until Fax appears and press Menu/Set.
- Press the up or down navigation key until Remote Fax Opt appears and press Menu/Set.
- Press the up or down navigation key until Fwd/Page/Store or Forward/Store appears and press Menu/Set.
- Use the up or down navigation key to select Fax Storage (or Off if you wish to disable Fax Storage). Press Menu/Set to confirm your choice.
- Press Stop/Exit to exit the menu.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Brother IntelliFax-2820 Plain Paper
Email this problem
Email this problem
Can you Help with these Fax Machines problems?
Brother IntelliFax-2820 Plain Paper Laser Fax
Paper jam will not go
Paper jam will not go away Answer This...
Can I use the all in one phone...
I have a MFC-665CW, I am... Answer This...
INTELLIFAX 2820--PAPER/SCANNER...
thx for prompt reply... Answer This...
not connecting to fax out
The fax machine recieves faxes... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
