Question about Samsung HL-S6767W DLP TV
I need to know where the #2 fan is located on my samsung HL-S6767W. Is it directly behind the back panel or somewhere around the Lamp? I keep getting a "Check Fan #2" on my screen, and I replaced the fan directly behind the panel, but it didn't work. Please help!
3 Suggested Answers
  • 11 Answers
SOURCE: my samsung hl-s6767w dlp keeps
this may be related to the power board or main board or even both.
Posted on Jul 29, 2010
Mas Baz
  • 177 Answers
SOURCE: Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Posted on Mar 30, 2011
Testimonial: "THANKS "
Samsung hl-s6767w timer reset. Can I reset using the menu option located on the tv. I have no factory remote
Yes, you just have to toggle manually using the plus and minus key as well as the channel up and down keys to navigate the menu
Nov 17, 2013 | Samsung HL-S6767W DLP TV
Hls6767w color fade off in 20min then turn itself off
the color wheel is faulty needs replacement the intermittent colors na fading is caused by the speed being not in sync with the dmd due to wear these and the fans are the only moving parts
Oct 23, 2012 | Samsung HL-S6767W DLP TV
hello Harley,
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
What is causing my picture to darken on my samsung 60 inch dlp tv
Most likely the tv projection lamp life are ending.The tv projection lamp been inside this tv like 1 1/2 or 2 years?Tv been on watches like 4 or 5 hours each day?The tv projection lamp life are ending,require a new tv projection lamp.
Jan 04, 2011 | Samsung HL-S6767W DLP TV
I have a Samsung DLP Model HL P5063W which has gotten increasingly loud, due to the cooling fan located directly behind the projection light. I took the light and the fuse panel away from the fan cleaned...
hi there.not sure on the shroud removal bit,but a good oiling of the fan bearings should fix the noise issue.its a common grumble with computers and suchlike.avoid wd40,it only lasts so long.engine oil is as good as any to use! hope the info is of some use! regards, steve
Oct 05, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Not really, tv is 6-8" from wall and nothing blocking vents, worked fine in same location for 10 months. could dust cause this type of overheating?
hi
10 months is a very small amount of time of dust problem but try to have a look to the fan near the lamp to see if it runs you should feel
the heat comming out
Sep 30, 2010 | Samsung HL-S6767W DLP TV
My samsung hl-s6767w dlp keeps shuting down. and tehree blinking lights come on
Jul 29, 2010 | Samsung HL-S6767W DLP TV
How to replace replace fan no.2 on Samsung HL-S4266w? how to re
tack out engine take out lamp take of lamp housing assembly replace fan
Apr 20, 2010 | Samsung HL-S4266W 42" HDTV
Samsung HL-S6767W DLP TV Logo
Jerry Greenberg
Jerry Greenberg
