Question about Refrigerators
Ice cubes melt together
After the ice tray fills with water, a trickle of water drips into the left rear corner of the ice bin and freezes most of the cubes together. I can't tell if the tray is overfilling or if there is a leak. The refrig is 18 months old. I attempted to level the ice tray but that didn't help. The temp never goes over 0 degrees F.
  • 2 more comments
  • oscar b May 25, 2008
    ame problem here m-- been going on for a few years
  • nfrees Mar 06, 2009
    We have a kitchenaid side-by-side refrigerator with no dispenser. The ice cubes freeze together. You can usually pull a few loose ones off the top, but the bottom 3/4 of the tray is a solid block of ice.
  • Anonymous Mar 22, 2014
    How can I stop ice cubes from freezing together?
  • Anonymous Mar 24, 2014
    ge model gfss2hcyc ss
    Genius:
  • 1,073 Answers
Check the fill cup on the rear of the icemaker to see if any ice is frozen in the fill cup if so remove the ice
Posted on May 06, 2008
Jennair jcb2058geb - ice maker continues to make ice but is dripping water into the collection bin and alll the ice cubes freeze together
The reason the fill tube is freezing is because the tube that connects to it and connects to the water inlet valve is seeping water slowly. It's just enough water to trickle into that tube at the top and since its so cold that little trickle freezes,then the next trickle freezes and so on and so on. After enough small drops of water freeze the entire tube is frozen. To stop that replace the water inlet valve the small diameter tube connects to. The part number for that is 12002193 you could purchase it at your local applianve parts store. Or online at
repairclinic.com
searspartsdirect.com
apdepot.com
apwagner.com
partselect.com
Thank you for using Fixya.com,
Gene
Sep 05, 2011 | Jenn-Air Refrigerators
I have a samsung rfg297aars refrig. I believe the water is leaking from the ice maker into the cube tray and running out and freezing in the cube dispenser and it is freezing the cubes together and...
you need to check the flapper in the door where the ice comes out,, if you take the ice bin out look down in the hole where the ice comes out,, if it is not sealing good it will let warm air come up the chute and melt the ice,, if it is sealing good,, then you need to check and see if the water fill tube( the one that goes into the icemake) is not froze up or has asomething blocking it
Jan 19, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Ice maker sprays water into the ice storage bin
you need to remove the i/m from the freezer and make sure the "fill cup" doesnt have an ice blockage. thats where the water has to funnel into the mold. it can get a drip into the cup and then freeze in the cup. clear it out once and try it again, but if it happens once or twice again , then you might have to replace the water inlet valve.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice tray sometimes stuck when dumping off ice
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Mar 24, 2008 | LG LSC26905TT Side by Side Refrigerator
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
The water continues to drip after the ice cube maker is full.
Sounds like the water fill solenoid valve is leaking by. You will have to change that solenoid valve if the water continues to drip into the ice maker tray after a normal fill cycle. http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=JCD2295HES&mfgModelNum=JCD2295HES&fkMfgID=1
Dec 05, 2006 | Jenn-Air JCD2295HES Side by Side...
Refrigerators Logo
614 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
