Question about Elmo Projectors TT-02U Camcorder
Flashing blue light/power button on Elmo. What does it mean????
Why wont my logitech boombox go into bluetooth search mode
I had the exact same problem. Boombox flashing blue, but not rapidly flashing blue. I did two things that seemed to fix it:
1: Reset the device by switching it on, then holding both volume up and volume down buttons at the same time for 10 seconds. The blue flashing light will briefly flash quicker to confirm.
2: Switch off the boom box
3: Switch on using the power button and (very important) immediately press and hold the Bluetooth button. The Bluetooth button needed pressing and holding almost instantaniously after the power button for it to work for me. I had to try several times to get it to work.
When you do this successfully, the Bluetooth light starts flashing rapidly and it enters search mode.
I nearly threw my speakers away, now it works and connects fine :)
Oct 10, 2012 | Logitech Radio Communications
My Elmo TT-02RX document camera is not working properly. The blue power light does not stop flashing when I turn it on, and I am unable to use the camera or switch over to projecting what is on my...
Your Elmo TT-02rx comes with a five year manufacturers warranty. Contact Elmo at 1-800-947-ELMO and they will instruct you as to how to trouble shoot your doc camera or send it in for warranty service.
Apr 14, 2011 | Elmo Projectors ELMO TT02RX DIGITAL...
Green camera light is flashing and image will not project. What can I do?
If you can post something offering a bit more detail, I can probably help you. Or you can call 1-800-896-3566 and ask to be connected to a tech. The TT-02rx comes with 5 year warranty.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
The power button flashes but there is no light.
Elmo TT02 models come with a five year factory warranty, and from my experience, Elmo will usually repair your camera even if it is out of warranty at little or no charge. Download the warranty service form from the following link:
http://www.elmousa.com/files/service1.pdf
Fill it out with your contact info and describe your problem. Box up your camera along with the service form and ship it the address on the form. Elmo will repair within several days and return it to you.
Please feel free to contact me at fkemmer@vsci.com or www.shopvsc.com if you have any additional issues. VSC is one of the largest Elmo dealers in the US.
Nov 04, 2010 | Elmo Projectors Elmo TT02RX Document...
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Blue flashing light on lumipure air purifier
I read on another site to hold the power button down for 5 seconds. Dont know what the blue light is but this stopped it from flashing!
Jun 13, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Rock band 2 for wii - accessory blue lights won't stop flashing
hold down the power button on the wii console till the light is red, the blue lights will stop blinking
Jun 10, 2009 | Nintendo Wii Console
ELMO document camera only shows documents in black and white, not color. Is there something wrong with the bulb? the camera?
My ELMO unexpectedly stops working during class. The blue power light is still lit but the ELMO is not recognized through my projector.
Any suggestions on what the problem may be?
Mar 25, 2009 | Elmo Projectors EV-200 Slide Projector
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Elmo Projectors TT-02U Camcorder Logo
819 people viewed this question
Top Elmo Projectors Video Cameras Experts
Are you an Elmo Projectors Video Camera Expert? Answer questions, earn points and help others
