Question about Epson Stylus 880 InkJet Color Printer
I interrupted the cleaning cycle of the printer head by requesting it be cleaned again before finishing the cycle. Now all the printer red lights are lon for printing, and both the color and black inks. Can't get lights off or printer to print. Help please
  • 514 Answers
Try unpluging for about 3 mins then plug in while holding the power button on, that may reset it to run. if not, then hold all buttons in for about 30 sec.s and it should start to run thru the reset cycle.
Posted on Sep 14, 2010
Stylus r300 printing orange photos why
Follow these steps to clean the print head from the printer's control panel:
1. Make sure the printer is turned on but not printing, and the red
b error light is off.
If the red light is flashing or on, you may need to replace the ink cartridge.
2. Press the down button to highlight More Options, then press OK.
3. Use the up or down button to highlight Head Cleaning, then press OK.
4. To begin cleaning, press OK.
While cleaning, the printer makes noise and you see a progress bar on the control panel
display. Cleaning takes about 30 seconds.
Caution: Do not turn off the printer or interrupt the cleaning process.
5. When the cleaning is done, run a nozzle check to confirm the print head nozzles are
clean.
Make sure letter-size plain paper is loaded in the printer, then press Stop. The nozzle check pattern prints.
6. If the pattern has gaps or missing dots, press Stop to clean the print head again.
If the nozzle check pattern looks correct, press OK to finish.
Note: Run nozzle check at least three consecutive times. If you do not see any improvement and you have replaced the ink cartridges, your product may require service.
Feb 14, 2013 | Epson Stylus Photo R300 InkJet Printer
My Epson C86 Printer is not printing - I've tried cleaning the heads (at least 10 times) but it is still not printing. Is there anything else I can do??????
Have you tried the steps below, if not, try them Turn on the printer by pressing the"Power" button. Check the red "Ink" light next to the powerbutton. If it is flashing, you need to first replace an ink cartridge. If the"Ink" light is off, proceed with the cleaning process. 2 Open the Epson Printer Utilityprogram installed on the computer connected to the printer. In the mainmenu, click the "Head Cleaning" option. Click "Start" tobegin the cleaning process. This may take several minutes. You will hear noisesfrom the printer and the "Power" light will begin to flash. 3 Load paper into the tray when the"Power" light stops flashing and you no longer hear noises. Click the"Print Nozzle Check Pattern" option on your screen, then click"Print" on the following screen. The printer will now print a testpage. 4 Click "Finish" if thetest page looks complete. If there are gaps in the image or white lines runningacross the page, the print head needs to be cleaned again. Click the"Clean" option on the final screen instead of "Finish" toclean the heads again. Once again, the printer will print a test page whenfinished. If the page does not meet your standards, clean the head until youare satisfied.
If this does not work, try the steps below.
The fix is described here:
http://inkjetprinterhelp.us/duraink.html
But I had a few problems trying to apply it. I wound up with one of those"extra" parts. (see http://www.fixyourownprinter.com/forums/printer/37654)
So, be advised that the fix is non-trivial to perform if you're a klutz likeme, and also you probably DON'T need to disassemble the print head. (On theother hand, if you DO disassemble the print head, and you see a little partlike the one I found, please tell me where it goes!).
Regards,
Ron
Feb 14, 2011 | Epson Stylus C86 InkJet Printer
Printer prints out blank pages
Follow these steps:
1. Load a few sheets of plain paper in the sheet feeder.
Turn off your printer.
Hold down the paper button as you press the power button to turn the printer back on. Hold down both buttons until the power light begins to flash, then release the buttons.
The printer prints its test page, which includes a nozzle check. Does the paper print out without any gaps or with gaps? If there are do this:
2. Load a few sheets of plain paper in the sheet feeder.
Make sure the printer is on and the ink light is off.
Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Head Cleaning.
Follow the on-screen instructions to start the cleaning cycle, which lasts about 1 minute. The power light flashes throughout the cleaning cycle and stays on green when the cycle is finished.
Caution:
Never turn off the printer during a cleaning cycle or you may damage it.
When the power light stops flashing and remains on, you can check to see if the nozzles are clean. Click Print Nozzle Check Pattern and click Print. Check the printed nozzle check pattern to see if there are gaps in the lines.
If there are no gaps, click Finish.
If there are gaps or the pattern is faint, click Clean to clean the print head again.
You may need to clean the print head up to 4 times. You can also turn off the printer and wait at least 6 hours. Then try printing again.
If this doesn't work then double check that you have the toner cartridges in correctly. If you do then your print head is broken and/or burned out and it's best to just replace the printer. Fixing it would cost more than the printer itself
Jan 17, 2011 | Brother MFC 420CN All-In-One InkJet...
Replaced the ink cartridge now it will not print
*** I'll be more than happy to help you on that.
there is a great possibility that the nozzles of your printer are clogged by dried inks.maybe cause by the previous inks that you just replaced. we can check that by printing a nozzle check pattern.
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX110 Series. 3. Hold down the nx110_tx110_ug.1.98.1.jpg Stop button as you press the nx110_tx110_ug.1.98.2.jpg On button to turn the Epson Stylus NX110 Series back on. When the nx110_tx110_ug.1.98.3.jpg On light begins to flash, release the nx110_tx110_ug.1.98.4.jpg Stop button. nx110_tx110_ug.1.98.5.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx110_tx110_ug.1.98.6.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Using the Control Panel 1. Load a few sheets of plain paper in the sheet feeder. 2. Make sure the Epson Stylus NX110 Series is on and the ink light is off. 3. Hold down the nx110_tx110_ug.1.99.1.jpg Stop button for three seconds to start the cleaning cycle, which lasts around one minute. The nx110_tx110_ug.1.99.2.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus NX110 Series during a cleaning cycle or you may damage it. 4. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 4 times. You can also turn off the Epson Stylus NX110 Series and wait at least 6 hours. Then try printing again.
Feb 16, 2010 | Epson Stylus NX115 All-In-One InkJet...
My r290 add red color to my photos
*** I'll be more than happy to help you on that. you might be talking about R280, because theres no R290 for epson. there is a great possibility thatsome of the nozzles of your printer are clogged by dried inks, thats why when it prints, the inks are not equally distributed or is not balanced.to check that, print a nozzle check, and if you see gaps or breaks, between the lines, do head cleaning. this is how you can do it, its very easy for you. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, that the CD/DVD tray is not inserted in the printer, and the red maint.5.1.8.jpg ink light is not on. (If the red maint.5.1.9.jpg ink light is on, you need to replace a cartridge.) 2. Turn the printer off and make sure the front tray is in the paper (lower) position. 3. Make sure letter-size plain paper is loaded in the printer. 4. Hold down the maint.5.1.10.jpg paper button, then press the maint.5.1.11.jpg power button. Hold down both buttons until the maint.5.1.12.jpg power light begins to flash, then release the maint.5.1.13.jpg power button. maint.5.1.14.jpg 5. When the nozzle check starts to print release the maint.5.1.15.jpg paper button. Check the nozzle check pattern that prints to see if there are gaps in the lines. maint.5.1.16.jpg 6. If there are no gaps or lines, the print head does not need to be cleaned. If there are gaps or lines, or the test patterns are faint, follow the steps in do the Head Cleaning to clean the nozzles. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, and the red maint.5.1.23.jpg ink light is off. (If the red maint.5.1.24.jpg ink light is flashing or on, you need to replace a cartridge.) 2. Hold down the maint.5.1.25.jpg ink button on the printer for approximately 3 seconds. The printer runs a head cleaning cycle and the green maint.5.1.26.jpg power light flashes. Cleaning takes several seconds. Caution:
Never turn off the printer while head cleaning is in progress. You may damage it.
Do not insert the CD/DVD tray until cleaning has finished. 3. When the green maint.5.1.27.jpg power light stops flashing, make sure paper is loaded in the printer, then print a nozzle check to determine whether you need to clean the print head again. Print Head Nozzles If you don’t see any improvement after cleaning three times, turn the printer off and wait overnight. This allows any dried ink to soften. Then, try cleaning the print head again.
Feb 16, 2010 | Epson Stylus R290 InkJet Printer
PLSE HELP IM TRYING TO PRINT BUT NOTHINGS HAPPENING, IT IS ALL SET UP
test the printer first, so that we can isolate the issue. print a nozzle check to eliminate the possibility that the nozzles are clogged by dried inks. if nozzle check prints blank page or it printedr but w/ gaps or breaks, do head cleaning
Check the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus CX4400 Series. 3. Hold down the cx4400_ug.1.79.1.jpg Stop button as you press the cx4400_ug.1.79.2.jpg On button to turn the Epson Stylus CX4400 Series back on. Hold down both buttons until the cx4400_ug.1.79.3.jpg On light begins to flash, then release the buttons. cx4400_ug.1.79.4.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. cx4400_ug.1.79.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Clean the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Hold down the cx4400_ug.1.80.1.jpg Stop button for at least 4 seconds to start the cleaning cycle, which lasts around 1 minute. cx4400_ug.1.80.2.jpg The cx4400_ug.1.80.3.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus CX4400 Series during a cleaning cycle or you may damage it. 3. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 2 times. You can also turn the Epson Stylus CX4400 Series off and wait at least 6 hours. Then try printing again.
Feb 15, 2010 | Epson Stylus DX4450 All-In-One InkJet...
INK DOES NOT FLOW. HOW TO CLEAN INK AREA.
Here is a few steps to clean the print head of your printer.
1. Make sure the CX5000 Series all-in-one is turned on but not printing, and the ink cartridges are not low or expended.
2. Right-click the printer icon on your taskbar (in the lower right corner of your screen). Select Head Cleaning.
3. Click Start or Next.
Cleaning takes several seconds. The CX5000 Series runs a head cleaning cycle and the On light flashes.
Caution:
Never turn off the CX5000 Series while head cleaning is in progress. You may damage it.
4. When the On light stops flashing, make sure paper is loaded in the CX5000 Series, then do the following:
Windows:
Click Print Nozzle Check Pattern. Then click Print.
5. If there are no gaps or lines, click Finish.
If there are still gaps or lines, or the test patterns are faint, click Clean to clean the print head again.
If you don’t see any improvement after cleaning three times, refer to Problems and Solutions. You can also turn the printer off and wait overnight. This lets any dried ink soften. Then try cleaning the print head again.
Tip:
If you do not use your CX5000 Series often, it is a good idea to print a few pages at least once a month to maintain good print quality.
Cleaning the Print Head
Hope this initial / info idea helps.
Dec 10, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Printer
One of the best solution that we can provide you is head cleaning. One of the effective method of Head cleaning is listed below.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START. Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) , your printer will require service.
Jun 03, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Black ink
Please try the following to resolved the issue:
Run a series of head cleaning
1. Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
3. Click on START, CONTROL PANEL, PRINTER & FAXES then right click on CX3200 printer Icon then select printing preferences
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Mar 02, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Dark red prints with lines throught the picture
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
Dec 23, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus 880 InkJet Color Printer Logo
132 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
