Question about HP Photosmart C6180 All-In-One InkJet Printer
I have a HP Photosmart C6180 All-in-One printer that is 3 years old. It has been a great printer for our home. Today it decided it would no longer print and I get the following message: Ink System Failure. Ink system has failed and can no longer print. Refer to printer documentation Error: Oxc18a0201 The proposed solution at the following HP link does not help: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=ca&lc=en&dlc=en&product=1153494 HP told me that to service the printer could be about $200 which is just about more than the printer is worth. Do I really have to buy another printer?
  • 100 Answers
I had an ink system error message on my C6180 that evolved into the printer power cycling every 15 seconds of so. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers produced by HP around this time. I have a HP Photosmart C6180 All-in-One printer - acca299.jpg
Posted on Oct 03, 2010
  • minpdx Jan 28, 2011
    This info has been so helpful along with this group of pictures:http://picasaweb.google.com/109215435720... The pictures show how to get to the logic board. Thank you for helping me fix my printer instead of turning it into a boat anchor!
Photosmart c6180 printer status offline
IF you have more than one printer set up on your system take all the others off except this one if you are able to without disrupting your home printing flow for others.
Another suggestion would be to download the newest drivers if you have not already; I found the site below with the drivers for this printer at:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&product=1153494&
Hope this helps.
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6150. Rollers do not pick up paper
Remove the rear cover a reallly scrub the black rollers with isopropyl alcohol. Scrub HARD
Jun 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 colors no good - missing colors & muted. No longer aligns print when requested, per HP note at end. Already cleaned print heads,[OK], aligned printer numerous times-doesn't work....
try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Apr 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer will only print, not copy fax or scan
It is possiblethat the all in one solution software you used in XP doesn't work with Vista, after some update or other. You did the right thing by uninstalling and reinstalling. Make sure you have the correct driver from the HP site..
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP C6180) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
NO HP Devices Found
check ip address in printer and adjust it in the computer properties for the printer
Nov 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Printer won't turn on
its the problem in the main board of the printer.
as u said the light in the poer supply goes on/off still replace the cord and check if it is the same then its definately the board problem
Nov 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart C6180 black cartridge not printing
me too . 2 cartridges became empty at the same time and printer
stop printing COMPUTER FILES . yet , printer IS functioning
as FAX printing device ...
Jul 02, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
258 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
