When i turn on the computer i get a black screen. I don't get a boot up screen or anything. I have tried unplugging all the drives and dvd players then tried turning it on and i still get a black screen. i tried removing the memory and nothing. Is it my motherboard?
  • 82 Answers
If you can hear a single beep coming from your computer when you turn it on, try using another monitor? it might be the monitor that is having the problem.
Posted on Aug 27, 2010
When I turn on my laptop pc every couple days a black screen will come up and the laptop stops processing. Why? How to fix it?
I would suspect a glitch in the MBR/software, a black screen with a white cursor in the top left, BUT, Try this , when you shut down always unplug, remove battery when you use at home connected to AC. At boot in BIOS, BOOT sequence, change to Boot from HDD first. Also remove DVD's, CD's from the DVD/CD rom drive, if the machine has boot from DVD/CD rom as a default, it will try to read the disk in the drive first, delaying a switch to second HDD boot. This is a general idea in the Boot sequence procedure: http://helpdeskgeek.com/how-to/change-boot-order-xp-vista/
Dec 25, 2012 | Acer Computers & Internet
Pxe e53 no boot filename received
Sounds like it is trying to boot from a lan or someplace other than your hard drive. Make sure you don't have a music cd or movie dvd in the cd/dvd drive. Turn the computer off then turn it back on and the screen for which key it says to hit to Change The Boot Sequence or Boot Order, then hit that key. You have to hit the key when you see the message or it will not work and you will have to reboot and start over. Select the Hard Drive as the boot device and let it boot up. If you are successful then each time you boot you will need to do this process unless you make it a permanent change.
To make a permanent change to the boot process turn the computer off, then turn it back on and watch the screen for which key it says to hit to get into the Bios or System Setup, then hit that key. You have to hit the key when you see the message or it will not work and you will have to restart and boot again. Once you are in the Bios or System Setup look for any reference to Boot, Boot Sequence or Boot Order. It might be a tab you you select at the top of the window. Change the boot order to CD\DvD as 1st and the Hard Drive as 2nd. This is the normal boot order so that if anything goes wrong with the hard drive, you can boot from the cd/dvd by putting in a repair disk or operating system disk. Just make sure you don't have a music cd, movie dvd or anything in the cd/dvd drive when you boot. Save the settings and exit the Bios or System Setup and Reboot.
Jun 05, 2012 | Intel D946GZIS Motherboard
No bootable devices
Make sure you don't have anything in the CD/DvD Drive. It sounds like your system is trying to boot from something other than your hard drive.
Turn the system off then press the power button to restart it. Watch the screen for which key it says to hit to Change the Boot Order or Boot Sequence and hit that key when you see the message. Select the Hard Drive as your boot device and let it boot up again. This is a temporary change that is only good for the current boot cycle.
It the system boots then you want to restart the computer and this time watch the screen and see which key it says to hit to get into the Bios or System Setup and hit that key. When it opens tab over to the Boot and set your boot order or boot sequence to have the CD/DvD drive 1st and your Hard Drive 2nd. This is the normal way so that if your hard drive ever fails to boot you can put a cd in the drive to remedy the problem. Otherwise, just make sure nothing is in the cd/dvd drive when you turn the boot the computer.
May 13, 2012 | Dell Inspiron 1525 Laptop
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
Turn it on and goes right to a black screen with a white flashing cursor. I cant do anything. please help
Hello dear,
If you are not getting any errors try to unplug and plug hard-drive and DVD drive cables(Both power and data).Hope it resolves your problem.
If you find this solution helpful don't forget to give feedback.
Regards,
Sandy
Jul 10, 2011 | Computers & Internet
I have the Aspire 5810TZ-4761 laptop. Black Screen Won't boot up
Does the dvd drive have a little hole that you can push a paperclip or some other thin itam like a needle in.
This is used to eject the drive manually.
you could also try removing and re fitting the dvd drive, this is usually held in with just 1 screw
Jul 09, 2010 | Acer Aspire 5520-5908 Notebook
My 5640 will not boot no signal to moniter or key board canot use recovery disc hard drive still running it was running then I got the black screen
Well, sounds like bad luck for you. No, seriously, could you have gotten a virus? We can get you out of this, but it will take a little fiddling inside your computer.
Take the skin off the system. Look for where your Hard Drive is mounted, usually above or below the Floppy drive ( if you have one ). Pull out the 4 pin DC connector going into your hard drive - it has red, Yellow, black and orange for SATA drives and red black black yellow for IDE drives. Fire up your computer and boot from CD or DVD. Go through your BIOS setup if you must.
From boot, do not say you want to reformat or anything nasty, just try to look around your bios screen for anything weird. You can plug in your SATA drive hot if you want, to see if it will spin up and show data on C: Write me back when you have done these steps.
Mar 22, 2010 | Computers & Internet
I turn the computer on and compaq comes up briefly with options to press F8, F10, or F12 then the screen is black with a white blinking bar in the top left hand corner but won't let me type anything. What...
The machine is trying to boot from a device either cd/dvd drive or the hard drive try taking out disks that maybe inside the drive otherwise your hard drive may be at fault. You could try downloading on another computer a hard drive test and burn it to cd and try booting off that to determine if the hard drive is faulty
Mar 18, 2010 | HP Compaq Presario V2000 Notebook
I am trying to replace the hard drive in my compaq evo n1020v. The problem I am having is that when I turn on the computer, it doesn't seem to be booting from the windows CD. It just sits there and does...
you need to set the jumper setting from your Hard Drive as Master Drive and the CD/DVD player is Slave then go to Bios settings then set 1st boot CD/DVD to boot the windows installer..good luck and have a nice day..
Jun 27, 2009 | Computers & Internet
Booting problems
As you probably have already figured out your motherboard is running into some type of error during the boot process. Try restarting the computer and pressing the del key several times after a second or two. Can you get into the BIOS now? The first thing I would do is to make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. Unplug your computer, plug it back in and reboot, paying close attention to anything that is displayed on the monitor and noting any changes from before. If nothing changes can you tell us some more about the status of the computer or what led up to this? Did you just build it; just install a new part, power problems, anything? Let us know what you turn up and please don?t forget to rate the posting.
Jan 06, 2007 | MSI KM4AM-V Motherboard
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
