Question about Ovens
We have a bottle gas cooker and the oven has suddenly refused to stay lit after the button is released. We have taken it to pieces and cleaned pipes and jets but still no dice. The valve which serves the oven splits into 2 and also serves the grill - which is still OK. Honestly - it's such a simple piece of kit, we cam't see what could really be wrong with it. Make is a Thompson.
  • cswaisland_d Aug 27, 2010
    Thanks - am writing this on behalf of hubbie (otherwise it would never get done) - I'm sure he knows - but which bit's the thermocoupling?
  • 17,130 Answers
As you mentioned it is a simple device but the logic you need to work on here is to see for the free flow of gas, the ignition part where the air is mix .
So the cleaningg is what we must do again but with a differrence. Use a good air jet-- from a compressor- and use some metal bowden to clean off any rust or partciles from within so that the flow is absolutely clean. clean the jets with a small wire/needle ( not to increase the dia) wash with petrol and dry.
make sure to use the air for testing of the gas flow ,from the valve end( disconnecct gas) repeat cleaning if not satisfied.
The important part here is a the Burner End. I suspect that there is some gap in the burner fitment, so remove use a good emery paper and polish to set it right so that the gas mixes well without being insufficient or difficient.
You will notice the difference in theflame , repeat to improve.
Posted on Aug 28, 2010
  • 10,865 Answers
Hello. Change the thermocouple on the oven and make sure that there's no clog in the gas pipe to the oven jet and that the jet orfice is clean. Thermocouple is easy to change and any local gas company should have a replacement or let them change it for you, beats spending money on gas to take it to the dealer. J.
Posted on Aug 27, 2010
Hi have a new world oven every time I push the switch in and release it the gas will not stay lit i
Call your gas company. they have a big interest in you not messing up. My PSEG will help me free of charge. it is important to not accidently kill you self or blowup the house.
Jan 06, 2018 | New World Ovens
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
Broken stove knob
simple flame sensors at fault eg thermocouples replace bad sensors and dsi box (direct spark ignition )
Apr 01, 2014 | Ovens
Oven pilot will not stay lit
Strange to hear about a pilot-flame. Is it an old oven? Commercial unit? Look for a small valve at the end of the pilot gas-line and see if it is shut off. If it's on, okay. But, is gas getting there being blocked elsewhere? There may be a flame safety-switch, a sensor by the pilot, or some other thing that has a release button for lighting the pilot. You hold it in until the sensor heats up, and then it will stay lit. After that, there may be a re-set button to get gas to the main burner element. Basically, you have to trace lines back until you find the hindrance. CAUTION:With all gas appliances, you have severe danger of causing an explosion, and untimely death, or injury, so if you have any doubts, get a qualified guy on it! (It takes a while to grow a beard back, too.)
Jan 05, 2014 | Garland Ovens
Oven wont lite
if its a pilot lightr that stays lit all the time,then its the thermocouple next to the pilot light thats bad and cant keep the pilot on
Nov 24, 2012 | Ovens
My ovens wont stay alight i have a twin range gas oven and it just wont stay lit but if i hold the knob in it stays lit
I offer free advice bcuz God is so good!
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
: I offer free advice bcuz God is so good!
Jul 31, 2011 | Belling Ovens
Gas wont stay lit after ignition
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | New World G60m Gas Single Oven
Beko SCG 7521 gas cooker flame won't stay lit in oven.Once you light the flame in the oven & hold in the oven button for the recommended 10 secs it cuts it's self off when you release the oven...
bloody hell that is so scarey i have the same problem and its round about the same time yours went funny if you have a solution can you let me know as im looking for the answer myself klass-a@hotmail.co.uk
Oct 08, 2009 | Ovens
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
Ovens Logo
32 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
