Question about Braun Health & Beauty
I have a braun model 5428 and need a new shaver head and module that fits the razor.
  • Braun Master
  • 1,623 Answers
You will find parts for Braun type 5428 at shaveroutlet.com. See link below<br /> <br /> <a rel='nofollow' href="http://shaveroutlet.com/catalogsearch/result/?q=5428">http://shaveroutlet.com/catalogsearch/result/?q=5428</a>
Posted on Aug 28, 2010
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
Batteries run down faster (Braun 7505)
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Jul 14, 2010 | Braun 7000 Series Foil and Cutterblock
The Charging cord's head that fits into the Shaver is broken. How get I get a replacement?
I have several new power charging cords for this model. If you want one Please let me know and will give you a good price.
Nov 13, 2009 | Braun 8585 Electric Shaver
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Health & Beauty
The razor head comes loose from the two arms.
The one piece motor drive which also contains the shaver head in the Braun wear out. They can be replaced by yourself or a shaver tech. A good place for parts, http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
May 27, 2009 | Braun Syncro 7526 Electric Shaver
I had a similar problem where one of the side covers popped off. I was able to reattach it, by carefully aligning the spring and pushing back into place. If you've lost the pin, you're out of luck. Braun does not make these kinds of parts available for user servicing, unfortunately.
However, the 7000 series models are all compatible with each other in terms of motor, battery, and razor head armature. You could try locating a moderately used example on the cheap (maybe less than $20) and then cannibalize it for the parts you need.
Do NOT send it off to Braun for servicing, as you will be charged much more than the shaver is worth. If it comes to that, you're better off just going with an 8000 series shaver.
Mar 11, 2009 | Braun Syncro 7526 Electric Shaver
Braun shaver model 5428
I have fixed mine. the pointy end fits in a hole next the the part that actuates the long hair trimmer (on the trimmer). this points out to the side of the shaver, and the rounded end fits into a little slot on the body of the shaver, slightly lower than the track the long hair trimmer slides along, and towards the top.its fiddly getting it all back together, but its perfect now. Dead pleased.
Sep 08, 2008 | Health & Beauty
Health & Beauty Logo
160 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
