Osd lockout comes up in middle of screen in white box then menus will come up and not allow to go through eventually will go through own thing and start all over w/ osd lockout msg...i have tried holding menu 10 sec no resolution also have tried restart computer...reset computer...disconnecting all cables from monitor with no resoltion?
    Sergeant:
  • 201 Answers
Hi How to Fix OSD Lockout Display on a Computer Monitor | eHow.com type this in your search engine.i used mozzila firefox to get to this .hope this helps.
Posted on Aug 27, 2010
How do I unlock the OSD lockout on a Samsung B2430H monitor. I've unplugged the power and computer connection cable. Tried holding the menu and auto keys nothing seems to work. There is just the...
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Sep 09, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
Brightness/contrast locked
All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
My monitor model is HPw1907 & every now and then OSD Lockout with white background is coming up in the central area of the screen. How to get rid off this problem. Pl. advise.
Hey there.
I have recently written a tip on this OSD lockout problem. I suggest you give it a read and let me know how it goes.
You can see my tip here: http://www.fixya.com/support/r9424404-fix_osd_lockout_or_screen_display
Enjoy my tip.
Slasher_X
Aug 23, 2011 | HP w1907 LCD Monitor
Hi i have a problem in my hp lcd screen.Its HP L1906 (19'') ,the problem is that the Main menu pops up without pressing the menu button .And a black phrase in a small white box in the middle comes...
Press the menu button and navigate until find "factory reset" and select ansav/exit.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 08, 2011 | HP L1906 19" LCD Monitor
How do I remove 'OSD LOCKOUT' from my monitor/screen?
Try holding the power button or the menu button of the monitor for about 5 - 10 seconds. This should remove the OSD Lockout message. Consult your monitor's reference manual if you still have problems.
Apr 11, 2011 | Computers & Internet
I have a w1907 HP monitor. It keeps displaying a small box in the middle of the screen that says osd lockout. I am still able to get online and use my computer normally except for this box in the middle of...
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work. To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Jan 03, 2011 | HP w1907 LCD Monitor
Ocd lockout
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | HP W1707 LCD Monitor
OSD Lockout bananas
Sounds like a button on the monitor is stuck in the depressed position.
May 30, 2009 | HP w1907 LCD Monitor
Osd lockout
If you encounter an OSD Lockout error with your monitor simply try the fixes on this page:
http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Mar 27, 2009 | HP w1907 LCD Monitor
OSD LOCKOUT
1. Replaced the Micro switchs.
2. press the menu switch 15 to 20 secunds.
Nov 02, 2008 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
