Question about VIA ASRock K7VM3 Socket A/ KM266PRO/FSB333/DDR333/A&V&L/Modem/MATX MotherBoard (MOTASR09)
My first PC build....gone horribly wrong =(
Ok,so i am building a pc with a Asrock K7VM3 motherboard, AMD athelonsocket 462 processor. i did my build in an atx case, with many casemods, and powered it with a ATX 550w power supply. I turned it on, andit went to boot mode, but the keyboard wouldnt work, and i tried threedifferent ps/2 keyboards, to find that it was most likely the board...so i took the cmos battery out and put it back in, as instructed... Nowthe machine wont power up at all..... So i bought a new motherboard,and IT wont power up either.. Did I blow the CPU? Or the power supply?What can/ should I do?????? Please help!
    Genius:
  • 3,422 Answers
Please CLICK HERE for more info on your power supply.
My guess is that your power supply is dead. If the fan doesn't spin it may be that the fan died first and the PSU overheated.
Now, if you are fortunate nothing else got damaged. You can remove the PSU (the mounting screws are on the back of the case, there should be four) and buy a new one at your friendly local computer parts store. Get one rated for at least as much power as the old one. We can give you a hand on this if you tell us what the lable on the side of the PSU says.
I should caution you that there is a chance that when the PSU went it damaged other parts of your system.
Goodluck..
Posted on May 07, 2008
HI this is pradeep iam using ASROCK motherboard processer AMD Anthlon(TM)XP2600+ for this motherboard which graphic card can i use my problem is i brought dell 24inch moniter ST2420L but graphic...
Asrock K7VM3 mother board with AMD Athlon 2600+ processor.
The Motherboard is having a AGP slot which says to use AGP with 4X and 1.5 V
Can someone suggest the market products available
when I contact the technical team of Asrock. they responded as below:
The AGP slot on K7VM3 is the standard AGP x8 slot , as long as the VGA card you want to buy is standard AGP VGA card , K7VM3 can support the standard AGP VGA card.
Or , you can double check your question with your VGA card vender before you buy it .
Oct 17, 2010 | Asrock K7VM3 Motherboard
Is the asrock k7vm2 motherboard easily replace by the k7vm4 asrock. my k7vm2 is dead and replacements are not easy to come by. I'm just looking for a new mother board to hook up to my hard drive and not...
You may be able to just swap out the motherboard for a K7VM4 motherboard but some of the specs are different like the chipset and graphics etc.
K7VM4 specs as follows >>>>
  1. Socket A(462) for AMD processor
  2. VIA® KM400 Chipset
  • ASRock U-COP
  • Hybrid Booster - a safe overclocking feature
  • FSB 333/266/200, DDR 333/266/200
  • Integrated UniChrome 3D Graphic.
  • 1 slot for AGP 8X/4X 1.5V
  • ASROCK I/O - default 4 ready-to-use USB2.0 ports on rear panel, default Game/MIDI port.
  • ATA 133 supported
  • On board default 10/100 LAN and 5.1-Ch Audio.
K7VM2 specs as follows >>>>>>>
  2. VIA® KM266 Chipset
  • ASRock U-COP
  • DDR 266/200
  • Integrated ProSavarage8 3DGraphic.
  • 1 slot for AGP 4X/2X universal.
  • Supports both DDR and SDRAM memory modules to provide you best flexibility and save your cost.
  • ATA 133 supported
  • On board default 10/100LAN and Audio.
As you can see the graphics and chipsets are different although the processor sockets are the same.
This could cause problems if you are going to plug the hard drive to another board but saying that is is possibe and has been done before.
This is a chance you take when you swap out a board for a different motherboard although i suspect that the transition should go smoothly.
A fairly old motherboard like K7VM4 or K7VM2 will not cost that much these days. You will find both motherboards for sale on eBay.
Regards.
May 27, 2010 | Asrock K7VM2 Motherboard
K7VTA3 v6.0 Motherboard - What Faster processor can I install
AMD Athlon XP 3000+(.13u) (512K,333,Socket 462) according to website
Dec 02, 2009 | EliteGroup ECS Motherboard MB K7VTA3...
I need a Asrock K7VM3 Models VGA Driver
Your driver can be downloaded from here.
Post your results back here, especially if this doesn't fix your problem...
Apr 02, 2009 | Asrock K7VM3 Motherboard
I m unable 2 find the vga drivers for AMD k7vm3 for vista. .
I m unable 2 find the vga drivers for AMD K7VM3 for Windows XP Professional
Mar 31, 2009 | Asrock K7VM3 Motherboard
CMOS Setting Wrong
Sure sounds like a motherboard issue to me!
Mar 28, 2009 | Asrock K7VM3 Motherboard
Friends custom-build PC has no power
Seems reasonable. Take the motherboard out of the case,  first to see if it will work outside of the case. Sometimes boards short to the ground due to a screw or other metal getting between them and the case. Try to run it with as little hardware hooked up as possible. You don't even need a hard drive to post the BIOS.
Mar 12, 2009 | Okia 420w UL Approved ATX Computer Power...
I want to updated my PC?
u can add some RAM Moduls with the same frequency of course.
also u can replace the vido card.
and the processor u can try the amd athlon series that fits the socket of ur pc.
Dec 08, 2008 | AMD Athlon XP 2000+, 1.67 GHz Retail...
K7VM3
An ASRock K7VM3.motherboard is a socket A (462) board specifically for the AMD processors. To my experience, these boards (due to age and period of usage) are prone to:
  • bulging/leaky capacitors of the high current regulators near the CPU;
  • the heatsink tends to be dislodged/misaligned causing overheated processor;
  • loose memory slots causing defective memories.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 02, 2008 | VIA ASRock K7VM3 Socket A/...
VIA ASRock K7VM3 Socket A/ KM266PRO/FSB333/DDR333/A&V&L/Modem/MATX MotherBoard (MOTASR09) Logo
193 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
