Question about Fargo DTC550 Thermal Card Printer
Print ribbon keeps breaking - Fargo DTC550 Thermal Card Printer
3 Suggested Answers
  • 6 Answers
SOURCE: Ribbon keeps breaking
It might be because the printhead is heating up too high, and burning the ribbon.
Try lowering the heat in the driver.
Posted on Jan 06, 2009
  • 4 Answers
Clean all the rollers. Try to calibrate the ribbon sensor. Check springs.
Posted on Feb 20, 2009
Printing to dark and intense. tightened screws now the ribbon keeps breaking and not print properly
It's hard to say based on the fact that your have already tightened screws. Without knowing which ones this may have caused the issue. One of the screws on the printer head is a set screw for the angle. If this is not set correctly it may break the ribbon. Based on your description of the colored ripples this means you are printing too hot and the ribbon is wrinkling under the heat. The only way to adjust this is to alter the printers internal head resistence settings. You would either have to succefully print a test card, or look at the under side of the print head to find the value. This should not be adjusted more then 300 points from the default value on the print head itself. to adjust go to printers and faxes, and right click the printer, go to printer properties (or just properties), device options, tools, properties, in the command line you must put the new value.
!R_XXXX ( where "_" is a space, and the xxxx is the value on the print head. hope this helps.
Oct 13, 2012 | Zebra P330i Thermal Card Printer
Ribbon breaking
Either to much heat or the support is unappropriate. Try to choose another ribbon quality
Jan 05, 2012 | Toshiba TEC B-572 Printer
The printer breaks the silver hologram ribbon everytime i print.it only break the silver ribbon when i do holograms
If your ribbon is breaking while printing a card, there area few things to look at.
  • Check that the printer driver has the appropriate ribbon selected. If a different ribbon is selected on the driver other than what you are using in the printer. Go into the driver and change the setting to the correct ribbon.
  • Another reason your ribbon may be breaking is because the "X" offset is set too low or too high, in other words the printing is beginning too close to the left side of the card, or ending too much to the right side so when the print head goes down to print on the card, the ribbon gets sliced because the print head and the edge of the card knife the ribbon. In order to eliminate this problem, increase or decrease the "X" offset value. I recommend a minimum of three digits up/down depending on the circumstance. For example: X-offset = 06...increase X-offset to 09. If the "X" offset is to high...EX: X-offset = 20...decrease X-offset to 17. Do not increase or decrease the value by more than 5.
  • If ribbon appears melted onto card, the print head may be damaged. Do not try adjusting. Immediately contact your re-seller or Zebra technical support.
  • If ribbon is breaking and nothing is being printed onthe card, contact your re-seller or Zebra technical support.
Dec 04, 2010 | Zebra P330i Thermal Card Printer
RIBBON BREAKE
Several things can cause a ribbon to break. Let's start with the simplest - cleaning. Use your cleaning kit to clean the rollers and print head. If the rollers are dirty, cards can slip and cause ribbons to break. Another is the TOF setting. If the print image is too close to the front edge, the ribbon will break.
Check these 2 things and see if this helps!
onlineidtech
Feb 23, 2010 | Fargo DTC-300 Thermal Card Printer
I have a zebra z6mplus the ribbon keeps breaking
You may have your contrast set too high. If it breaks as it feeds under the printhead (while printing) your contrast may be set too high.
You also could have a ribbon spindle issue. Are both ribbon spindles turning?
Jul 08, 2009 | Zebra Z6M Plus Thermal Label Printer
DataCard printer ribbon breaks
First, what color is it breaking on? Yellow, Magenta, Cyan, Black, Topcoat?
Next, I would do is clean all the rollers in the printer with isoprophyl alcohol (99% if you can find it, 91% is ok, 75% is you're in a bind). This is a common problem
Then, load the Printer Diagnostics from your print driver CD. In diagnostics, you can set the BASE POWER for YMC, K or Topcoat. The base power is totally different from intensity. As the printhead gets old, you may need to back off the intensity to keep the ribbon from breaking.
Lastly, take a look at the ribbon:
Is the image placed in the same spot of the ribbon on each panel or does it move (creep) higher or lower? This creeping action is caused by many things and would be best to be serviced by a technician.
Finally, printhead replacement. About $695 MSRP
May 26, 2009 | Datacard Group ImageCard Platinum Printer
Ribbon is breaking constantly in every print of card
in order of most likely
1 edge to edge settings in printer tool box are off.
2. print ribbon carriage (blue part you put the ribbon on is bad)
3. Bad ribbon
4. dealer needs to service to calibrate print head temp
tulsabiz.net for more info
Mar 27, 2009 | Datacard SP35 Printer
Dec 31, 2008 | Fargo Persona C11 Thermal Printer
Data card sp35 plus ribbon break
There could be either of the following issues:
1. Check the print head temperature to make sure that it is hot enough to transfer the ribbon to the card.
2. The surface of the PVC card may not be image compatible. Try another brand of card or opt to 60/40 composite cards for testing.
For technical assistance by blog for id card printers, see our blog at www.safecardid.com/blog/
Jun 20, 2008 | Datacard SP35 Printer
Fargo DTC550 Thermal Card Printer Logo
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
pkwc
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
