Question about Maytag Neptune MAH5500B Front Load Washer
My maytage neptune washer is flashing PF what does that mean?
  • 4,323 Answers
Hi
Error code PF means power failure. This happens when there is a power surge or the washer is unplugged manually. To reset this error you'll need to turn off the washer and unplug it for 10 minutes. Restart the washer and check, If the error still appears then pressing the Spin Speed key will begin the Board Output Test. This test turns ‘ON’ a specified output after a key press. Pressing the Spin Speed key again cancels the test. Please post back for further assistance if required.
Daniel
Posted on Aug 28, 2010
How to reset pf code on maytag neptune washer
codes can be reset by simply unpluging it for 5 min. how ever neptunes are what put maytag out of bus. with mo. # i can get more info and tell you what that code means
Sep 15, 2016 | Maytag Washing Machines
How do you fix the maytag neptune pf code for the dryer??
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Codefor Appliances
heatman101
Apr 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune dryer won't start has power lights will come on but ut won't run flashed PF before it quit
Hello & Welcome to FixYa
PF error code means power failure and is displayed when the circuit board also known as the electronic control board goes bad and needs a replacement. Before replacing the control you can also check the thermal fuse which is inside the rear panel on the blower wheel housing and replace if it reads no continuity. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I get a PF error. That goes away and shows 52 in the display. The buttons light up, but pressing any buttons does nothing but to make 3 beeps.
PF is Power Fail, means the Power was cut off. PF Power failure Power to the machine has been lost during the last cycle. This may occur on start up of a new machine due to factory testing.
Mar 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer did not finish it's load and was flashing pf what does that mean there is still a little water in bottom
PF code is for power failure.check electrical connection at wall and also make sure you dont have a bad breaker in the fuse box.If every thing there is ok check power connections inside washer
Mar 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Error code PF
PF means Power Failure!
Unplug both units for 10 minutes, then plug them back in and try operating them. You may need an electrician to investigate why you are losing power to both units
Jun 04, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error code PF
THIS is a "Power Failure " Clease the code (press Cancel button) and see if it starts up
Jan 23, 2008 | Maytag MAH8700A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
3,078 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
