Question about Briggs & Stratton Garden
I have an xmark tractor with a Briggs & Stratton 25 HP intek v-twin engine. The engine turns over very slowly and usually just stops after about a half turn when trying to start on battery voltage alone (either its own battery or when jumped to a non-running car). If I jump it from a running car, it usually starts right up. Sometimes, however, it does turn over slowly and stop even when jumping from a running car. Another hit of the key usually gets it going in this situation. Any ideas what my problem could be? I'm thinking that the decompression feature is not working properly. How would I go about checking/adjusting this? I have also seen a couple of reports here where a new starter seemed to fix a similar problem. My plastic starter gear has stripped off all its teeth once and the new one seems to be getting beat up a little already, so it seems to me that that my engine must be harder than it should be to turn over rather than my starter being weak. Any thoughts on this? Thanks,
    President:
  • Briggs & Str... Master
  • 1,545 Answers
I feel you are in the ballpark with the decompression feature. The Inteks have them alright. The best way to get the feature to work correctly is very simple. Adjust the valves. Just pull the valve covers off and set the valve lash.Torx head screws and locknuts are on the rockers. It isn't real hard. That should "enable " the compression release feature and possibly eliminate your starting problem.
One the engine hits about 300 RPM, the compression release feature is disengaged and no longer a factor.
Intake and exhaust valve clearances for your particular model are available on the Briggs and Stratton website if you look around.
Posted on Aug 27, 2010
  • Roy Cagle
    Roy Cagle Aug 27, 2010
    For the correct adjustment of the valve lash and operation of the compression release, the piston must be 1/4" below TDC on the compression stroke when the valves are adjusted.
Brigss and Stratton engine getting to much fuel
I HAVE A BRIGGS & STRATTON INTEK 18.0 ,JUST FINISHED CUTTING THE YARD,WENT BACK ABOUT 20 MINS LATER TO PUT LAWN TRACTOR AWAY. WILL NOT TURN OVER WHEN I TRY TO START, FUEL LEAKS OUT OF THE EXHAUST AND AROUND THE BOWL
Jun 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
On a 2-cylinder, 25 hp Briggs & Stratton INTEK twin engine (year 2002, Model 44577-0134-E1), there is a ~1.5-inch rubber hose to the top of the right OHV cover coming down from a round plastic piece in...
Ok I haven't worked on this exact model before but Im curious if the engine runs?
It sounds to me like a fuel pump that uses crankcase pulses to pump the fuel. It is very common way to pump fuel but usually the pump portion is in the carb and not the fuel line.
If it were attached to the intake Id say it was a crankcase breather.
May 01, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
450 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
