Question about Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard
FATAL PROBLEM: -->A required texture format
FATAL PROBLEM: -->A required texture format (DXTC) is not supported by your display adapter.what should i do?
    Problem Solver:
  • 14 Answers
DXTC is an acronym or stands for DirectX Texture COmpression.
The three algorithms are different only for the alpha channel compression, the RGB part is exactly the same for all three. So if you don't need alpha blending you should use DXT1, as using DXT3 or DXT5 will only double dds file size without any improvement in visual quality. Instead, I regularly find out in texture replacement lots of DXT5 compressed textures with the default white alpha channel.
So what i suggest is you download a directX and if you will delete a games of software dont update the directx
Posted on Aug 27, 2010
How do you get a texture pack in minecraft
All texture packs work for Mac. Simply go to: Library > Application Support > Minecraft > texturepacks
Download the texture pack you want, unzip it so it becomes a folder. Put the folder of the downloaded pack in the texturepack folder.
Cheers
Mar 18, 2014 | Apple Computers & Internet
Texture is too large:2048x2048, maximum supported size: 1024x1024
To change these settings go: (Windows 7)
Control Panel > Display > Screen resolution [Change to 1440x900]
then on the same screen, go to Advanced Settings > Monitor > Screen Refresh Rate [Set to 60 Hertz].
(This usually happened if you switched monitors, or used a TV, or maybe a projector).
You can use the same method to set up any resolution or refresh rate you want.
Sep 23, 2011 | HP Computers & Internet
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
May 25, 2011 | OKI C5200n Laser Printer
When ever i click on go to race on need for speed pro street it freeze's
Most of the games that we like is the one has a better graphics and texture. To be able to run/play a specific game, you'll need to support the hardware requirements specially Graphics Adapter (Video Card). Don't get mad when your trying to play a High Graphical Texture game, and it run so slow.
This is some solution to boost your game movement -Go to Option->Video/Graphics->Set it all to low graphical quality, or disable some graphical texture settings..
I hope it will help you..
May 21, 2011 | Computers & Internet
Gigabyte gt 240 Game textures not displaying correctly
might be a power problem check the wattage of your card and the output wattage of your power supply it should be at least 20% higher than your card 450 card 650 power supply
Jan 24, 2010 | Computers & Internet
Can anyone please tell me if my video card is a capture card? Nvidia Geforce 6200 thanks joe
Tech Specs CineFX 3.0 Shading Architecture
  • Vertex Shaders
    • Support for Microsoft DirectX 9.0 Vertex Shader 3.0
    • Displacement mapping
    • Geometry instancing
    • Infinite length vertex programs
  • Pixel Shaders
    • Support for DirectX 9.0 Pixel Shader 3.0
    • Full pixel branching support
    • Support for Multiple Render Targets (MRTs)
    • Infinite length pixel programs
  • Next-Generation Texture Engine
    • Up to 16 textures per rendering pass
    • Support for 16-bit floating point format and 32-bit floating point format
    • Support for non-power of two textures
    • Support for sRGB texture format for gamma textures
    • DirectX and S3TC texture compression
    • Full 128-bit studio-quality floating point precision through the entire rendering pipeline with native hardware support for 32bpp, 64bpp, and 128bpp rendering modes
64-Bit Texture Filtering and Blending
  • Full floating point support throughout entire pipeline
  • Floating point filtering improves the quality of images in motion
  • Floating point texturing drives new levels of clarity and image detail
  • Floating point frame buffer blending gives detail to special effects like motion blur and explosions
Intellisample 3.0 Technology
  • Advanced 16x anisotropic filtering
  • Blistering-fast antialiasing and compression performance
  • New rotated-grid antialiasing removes jagged edges for incredible edge quality
  • Support for advanced lossless compression algorithms for color, texture, and z-data at even higher resolutions and frame rates
  • Fast z-clear
  • High-resolution compression technology (HCT) increases performance at higher resolutions through advances in compression technology
UltraShadow II Technology
  • Designed to enhance the performance of shadow-intensive games, like id Software's Doom 3
TurboCache Technology
  • Shares the capacity and bandwidth of dedicated video memory and dynamically available system memory for optimal system performance.
PureVideo Technology
  • Adaptable programmable video processor
  • MPEG video encode and decode
  • High-definition MPEG-2 hardware acceleration
  • High-quality video scaling and filtering
  • DVD and HDTV-ready MPEG-2 decoding up to 1920x1080i resolutions
  • Dual integrated 400 MHz RAMDACs for display resolutions up to and including 2048 × 1536 at 85Hz
  • Display gamma correction
  • Microsoft® Video Mixing Renderer (VMR) supports multiple video windows with full video quality and features in each window
Advanced Display Functionality
  • Dual integrated 400MHz RAMDACs for display resolutions up to and including 2048x1536 at 85hz
  • Dual DVO ports for interfacing to external TMDS transmitters and external TV encoders
  • Full NVIDIA® nView™ multi-display technology capability
Advanced Engineering
  • Designed for PCI Express x16
  • Support for AGP 8X including Fast Writes and sideband addressing
  • Designed for high-speed GDDR3 memory
  • Advanced thermal management and thermal monitoring
NVIDIA® Digital Vibrance Control™ (DVC) 3.0
  • DVC color controls
  • DVC image sharpening controls
Operating Systems
  • Windows XP
  • Windows ME
  • Windows 2000
  • Windows 9X
  • Macintosh OS, including OS X
  • Linux
API Support
  • Complete DirectX support, including the latest version of Microsoft DirectX 9.0 Shader Model 3.0
  • Full OpenGL support, including OpenGL 2.0
GeForce 6 Series GPUs Features Comparison:
Feature GeForce 6800
Models
shim.gif GeForce 6600
Models
shim.gif GeForce 6200
Models
w/Turbocache
shim.gif Microsoft® DirectX® 9.0 SM 3.0 SM 3.0 SM 3.0 SM 3.0 Graphics Bus Technology AGP 8X/PCI Express AGP 8X/PCI Express AGP 8X/PCI Express PCI Express NVIDIA® Intellisample™ Technology 3.0 3.0 3.01 3.01 NVIDIA® SLI™ Technology X2 X2 n/a n/a NVIDIA® PureVideo™ Technology X3 X3 X3 X3 NVIDIA® TurboCache™ Technology n/a n/a n/a X4 64-bit Texture Filtering and Bending X X n/a n/a Effective Memory Interface 256-bit 128-bit 128-bit 128/64-bit Memory GDDR35 and DDR GDDR35 and DDR DDR DDR Process 0.13 micron 0.11 micron 0.11 micron 0.11 micron RAMDACs 400 MHz 400 MHz 400 MHz 400 MHz
1. GeForce 6200 models do not include compression technology.
2. NVIDIA SLI: Available on SLI-certified versions of GeForce 6800 Ultra, 6800 GT, 6800 GS, 6800, 6800 XT, 6800 LE, 6600 GT, 6600, and 6600 LE PCI Express GPUs only.
3. Features may vary by product. Some features may require additional software.
4. Available on select GeForce 6200 models only.
5. GDDR3 - GeForce 6800 Ultra, 6800 GT, 6800 GS, and 6600 GT only.
Nov 20, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Missing texture
You should first check your system requirements, and see if you have the right graphics card.
Otherwise, go to Start Menu-->Control Panel--> Display-->Settings. Then tamper with the Color Quality, and the Screen Resoulution.
Hope this Helps.
Levi_xx
Jul 10, 2009 | EA Sports Cricket 07 for Windows
Missing texture message appears when it loads
follow my steps
first solution: go to run-->dxdiag--->select hardware acceleration to standard and save it
or
second solution: right click in the desktop and select the properties and select the setting--> advanced and select hardware acceleration to medium and check the display properties and check the texture level
Feb 12, 2009 | EA Sports Cricket 07 for Windows
Fatal error when running devil may cry 4 pc version
your graphics card probably couldnt handle that part fo the game, check your graphics card that it meets the requirements for the game. if they meet it then check your RAM.
Nov 26, 2008 | Capcom Devil May Cry 4
GeForce 6200
my recommend for that is format your pc.... insert first your agp then format the drive......
Jul 12, 2008 | XFX GeForce 6200 Graphic Card
Intel CELERON 2.66Ghz CPU AND MOTHER BOARD (CPU4266CEL) Motherboard Logo
493 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
