Question about Philips 60P8341 60" Rear Projection Television
60in philips tv model 60p8341
When turn on it takes a long time to come on we have to push the on button several times before we get a picture, we get no picture or sound until it connects on
  • Philips Master
  • 19,396 Answers
How comes that a problem submitted May 10, is coming back today?
Have you solved the problem?
Is it still the same problem?
Any update?
Posted on Oct 11, 2008
  • 3,037 Answers
It doesn't seem to be getting enough power on startup. Most likely the capacitors should be replaced. You can get them pretty cheap at the local Radio Shack. If you are replacing them yourself, remember that they carry a lot of power and need to be discharged before getting taken off. you can use a high wattage resistor of 5-50 ohms to do this. and check with a meter while it is discharging. Please let me know if you have any further questions, thanks
Posted on May 10, 2008
  • Benjamin Patri
    Benjamin Patri May 14, 2008
    Please don't forget to let me know your thoughts about my
    solution.
    If your problem is fixed, please rate this solution as that is one of the
    biggest aspects of how this website works and in order to receive any credit in helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to
    help.
    Thank you
    Genius:
  • 3,587 Answers
Sounds like the power supply or system board is going a tad soft...are you planning on calling a service professional or doing this yourself?
Black screen
It is likely that you now have power supply trouble.
May 26, 2013 | Philips Televison & Video
My Philips 60P8341 TV would not turn off. Turned off power strip and tv would not turn on. Waited an hour and tv turned back on, then tv turned off and power button blinks and then theres a click the...
Your convergence board is faulty. Common problem for this model. Pull the back cover off and look to the north and look for a jumper jack [1516 i beleive] and pull this off. [TV unplugged of course] Now plug in the tv and power up...If the picture is distorted you have bad convergence ICs. If picture is good...you may a bad audio IC. You can do this, just be dang careful and good luck to you!
Nov 25, 2009 | Philips 60P8341 60" Rear Projection...
Will not power on.
its either the fuse or the main filter panel ( power Board) You can get replacement boards at the following link with free tech support to help install if needed.
http://servicemanuals.vstore.ca/
Apr 02, 2009 | Philips 60P8341 60" Rear Projection...
Question about Philips 60P8341 projection tv
Vertical protection is what the two error code is. You can get a new Vertical output IC at the following link just leave them a email indicating your model number and what youre needing. They respond quickly.
Sep 22, 2008 | Philips 60P8341 60" Rear Projection...
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
60" philips projection tv
HI I AM HAVEING PROBLEMS WITH THE VOLUME THERE IS NONE AND NONE OF THE BUTTONS IN FRONT OF THE T.V ARE WORKING HELP PLEASE
Mar 07, 2008 | Philips 60P8341 60" Rear Projection...
60P8341 Rear Projection - Remote does not work
Your TV needs the part 313501707611 - it's the keyboard that's the cause of your problems - but here's the catch... Philips does not make that part anymore... they say that you need to either find someone to fix the keyboard (which I've had no luck on) or buy a new Television from them... hmm, a $2000.00 TV that needs a $20.00 part now becomes a plant holder in my living room because Philips wants us to purchase a new TV from them.
Oct 06, 2007 | Philips 60P8341 60" Rear Projection...
Tv reacts very slow
the problem is due to the crystal which sets the speed of the processor and it may be dry due to heat if that crystal is replaced or dry soldered the problem can be solved
Jun 27, 2007 | Philips 60P8341 60" Rear Projection...
Phillips tv 60p8341
You should probaly get the service manual. you can get one at the following link for 15.99 and they provide free support to help you diagnose the set. they email them out fast after placing a order. Have used them many times.
May 29, 2007 | Philips 60P8341 60" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
