Question about D-Link AirPlus DI-524 Wireless Router
My router went to all lights on and i resetted it and now only the power and status lights are on but i try to put the internet cable into it and it says it works and the wan is flashing but the staus keeps flashing and wont let me connect to the internet wirelessly but the cable works cause if i plug it into my computer it takes me roght to it but i dont know what to do
  • 220 Answers
Go to:
Start/Control Panel/Network Connections and right click on Wireless Connections then left click on Repair
This works sometime. Also you might want to restart your modem as well as your computer to get everything in sync.
Posted on Aug 27, 2010
Router dsl3780 red internet light keeps coming on
Usually indicates problem with the router's internet connection. Check the LAN cable between your internet modem and router and try a new cable. Reboot both devices. Direct connect to the internet modem to see if it is working correctly with interruption.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Nov 21, 2013 | D-Link Computers & Internet
Dlink dhp-302 red light is on
The router is not connected to the internet. Check the cable from the router to the modem - try a new cable. Reboot both devices. Connect a computer directly to the modem to make certain you have internet.
Jun 23, 2012 | D-Link Computers & Internet
I have a Linksys WRT54G2 Router, It Has Worked Fine For About A Year, And Just Suddenly It Has Problems, The WLaN Light Isn't On At All, The Power Light Is Just Blinking At A Steady Rate. I Can't Access...
Please make sure that Power, Internet and Wireless Light (or LAN light if trying to connect with Ethernet cable) is there on router if you are trying to connect it wireless .
And if only Power light is there only.Please try to power cycle the router ( turn off the router from power supply wait for a minute, plug the power supply back) and then again check the light status.
Even after this if same light status is there please try to reset the router ( there will be small pinhole button on the back side of router) just press it for 15 seconds and then release it.Wait for 2 mins and check the light status again.
It will fix your problem.
Please share the results.
Dec 09, 2010 | Linksys WRT54G2 Wireless Router
Modem light keeps blinking Have tried resetting. Restoring to default settings. If I hook the computer directly to the time warner modem I can acces the internet fine. Thanks
If the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
How to configure the router for Time Warner?
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
3.Under Internet Settings, change the connection type as Dynamic.
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 10 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
For any advanced help, revert asap!
Thanks and regards,
Arvind
Jul 04, 2010 | Belkin F5D8236-4 Router
Unit will not turn on anymore
First reset all settings of your router to factory defaults.
You can reset it with RESET button it is in back side of router.press it for 10 seconds.
Then check led status.
Disconnectr all connection from router then reconnect then check.
Soemtimes power problem create this problem .
Change your main power supply also check after change power adapter.
check ADSL cable ethenret cable to .
If still face same issue then your router has some hardware issue.
Let me know if you need more assistanse.
Thanks.
Sep 03, 2009 | Computers & Internet
D-link dir-615 cannot connect to internt
it could be a problem with your internet connectivity. check with the isp.
Jul 26, 2009 | D-Link DIR-615 Wireless Router
Cant get internet on both computers using router
When did the router stop working?
Have you tried a new cable between the router and the modem?
Since the status light is off on the router, that tells me that there is no communication between the router and modem. Is it possible that the router was reset by accident? Resetting it will put all settings to default. If it has been reset then you need to sign on to the router to setup the communication again to your modem. Typically this is done via the IP address.
I can walk you through those steps if that is the case. Try supplying a different cable though between the router and modem. Power off both of them, power on the modem and then power on the router....then try to connect to the Internet.
Mar 26, 2009 | D-Link DI-624 / DWL-G520 Kit...
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
Light Status on Netgear WGR614
Access router. What does it say? did you set up the wireless network yourself? Is the cable modem working properly? Rebooted it? Is there a problem with the internet provider?
Dec 14, 2008 | NetGear WGR614 Router
My wireless-G router with spdboster isn't working
Try to reset the reset button of the router to return to his default configuration and try to connect. Look for the pin or ballpen then press the reset at least 15 second.
Apr 17, 2008 | Computers & Internet
D-Link AirPlus DI-524 Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
