Question about Microwave Ovens
Need a user guide for sanyo microwave EM-S1298V
MicrowaveSvc
  • 9098 Answers
SOURCE: Sanyo EM S8000-w microwave range quit..fuse?
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
SOURCE: Service manual of microwave SANYO EM-D953
hi
If you are still looking here is tthe link for the instruction manual for that model which is the same one i have used for years
http://www.sanyo.co.uk/download/1659661.pdf
Have fun
Posted on Jul 04, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: USER MANUAL FOR SANYO MICROWAVE EM-D975
You can find several models of Sanyo microwave manuals here. Even though yours may not be there, there might be one close enough to help you.
If not, contact them through the links on that page.
Posted on Nov 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: lamp replacement in a sanyo microwave EM-D9553
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Jun 08, 2009
  • 72 Answers
SOURCE: is it possible to download the user manual for
Look up " http://sanyoservice.com/osb2/itemdetails.cfm?ID=1202 " on your
computer. If you can read and download a pdf file you'll have your manual.
Posted on Nov 12, 2009
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
User manual
Call the company who manufactures your a Sanyo Convection and ask them to send you a user manual guide. Make sure you give them the grill model number.
Apr 11, 2014 | Sanyo EM-G2585W Microwave Oven
I have a Sanyo EM-S1298V microwave which will not start. I program the power level then turn the timer knob but it will not start when I press the button. However the timer continues to count down.
No I have not, it's not the door micros witch.
A couple of symbles come on the control panel with I cannot find out what they are
i am sure it's a simple problem, but the manual, which came with the unit, does not have a decode for the symbles on the control panel
Oct 21, 2013 | Sanyo Microwave Ovens
I need a user manual for a Sanyo super showerwave 800w microwave. Model no. EM-G204 There aren't any on manuals online. Thanks Luke.
You can just type "EM-" (without quotes) in the search box at the Sanyo (Panasonic) support site here.
Check a few of the first results to see if they're close enough to help you.
If not, contact them via that page for more help.
Aug 22, 2012 | Microwave Ovens
My user manual has been accidently destroyed, and I would like to obtain a replacement copy. Am willing to pay for it. Please can you help me obtain one? Many thanks, regards Elaine
For download, visit this link: Microwave Oven SANYO EM-C8787B User Guide
Previously, check one or two stars and send few comments to access at PDF file download.
Hope helps (remember to rate this answer).
May 23, 2011 | Sanyo EMC8787B Microwave Oven
Need a user manual for a Sanyo Convection and grill model em-d981
Need one too - if anyone has one that is in .pdf format they could send it would be much apreciated
Jun 06, 2010 | Sanyo Microwave Microwave Oven
Is it possible to download the user manual for sanyo em-sl30n microwave oven
Nov 12, 2009 | Sanyo EM-Z2100GS Microwave Oven
Nov 20, 2008 | Microwave Ovens
Need users manual
You can find several models of Sanyo microwave manuals here. Even though yours may not be there, there might be one close enough to help you here.
Jul 07, 2008 | Sanyo EM-P540W Microwave Oven
Microwave Ovens Logo
70 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
