Question about Garmin nuvi 350 GPS Receiver
How does teh suction cup ball fit into the garming 360
I can't figure out how the ball onteh suction cup arm fits into the garming 360
Greetings,
There is a seperate black clip that should have come with your gps if you purchased it new. Here is a link to Amazon to get a better idea of what I am talking about:
https://buy.garmin.com/shop/shop.do?pID=8125#
If you have the clip then there is a round indent in it that requires a good measure of force to attach to the suction cup mount.
Take Care,
-WN
Posted on May 07, 2008
Danbury clock 'things remembered'. How do I access the battery? I cannot figure out how to find the battery. The battery is dead after two years and I need to replace it. It is not obvious how to...
The things remembered clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes out. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
Jan 31, 2014 | Watches
I can't figure out how the two pieces of the window mount fit together. Do you have an illustration of how it assembles?
The arm of the Garmin G-Ball Suction Mount snaps into the back of the cradle.
You can see a picture of it here.
http://www.gpscity.ca/garmin-nuvi-12xx-13xx-and-2xx-suction-mount.html
Sep 16, 2011 | Garmin Nuvi 265W GPS Receiver
How to replace a lower ball joint on 2004 mercury mountaineer?
Remove the brake caliper by removing the two bolts that connect it to the steering knuckle. Remove the lower ball joint cotter pin and retaining nut. Pry the steering knuckle up and away from the lower ball joint. Unscrew the grease fitting from the bottom of the lower control arm. Press the lower ball joint out of the control arm using a ball joint remover set.
Press the lower ball joint into the control arm using a ball joint installation tool. Remove the block of wood supporting the upper control arm. Install a new cotter pin through the ball joint stud.Install the grease fitting on the bottom of the ball joint. Use a c-clamp to push the piston back into the brake caliper. Reinstall the wheel assembly. Here you can find the quality parts http://www.buyautoparts.com/steering_system.htm
Aug 29, 2011 | Mercury Mountaineer Cars & Trucks
I can hear the motor running on the wipers but they won't move
You may have to access the wiper transmission . some times the plastic cup breaks or comes off of the wiper motor arm . they use a press fit on a cup and ball socket to attach the wiper transmission to the wiper motor there is a metal arm bolted to the wiper motor with this ball on it . The wiper transmisson is located under the front cowel i am not sure if you can look through the cowel vents to see the wiper transmission or not . I belive NAPA can and does stock some of these wiper transmission if the ball and socket are damaged .
Mar 07, 2011 | Pontiac G6 Cars & Trucks
How do you attach the grip to the suction cup before you can mount on the windscreen
On the end of the suction cup there's a ball shape. On the grip there's a small plastic cylindrical piece. Push the ball into the cylindrical part. It's a tight fit so you'll have to push hard.
Sep 25, 2010 | Garmin nuvi 255W GPS Receiver
How to replace a lower control arm and ball joint
not difficult to do just need a nice crowbar and a big hammer ,soak bolts in engine oil firsat overnight then undo the bolts ,seperate the balljoint by wacking on the side with the big hammer and away you go ,refit the arm to chassis first then fit teh ball joint
Jul 24, 2010 | 1992 Toyota Paseo
How do I attach my garmin to my dash mount?
The Garmin Nuvi 255w comes with a three piece dash mounting kit. A round disk smooth on one side tape on the other to affix to the dash (most dashes ar textured and the suction cup will not hold to textures) a suction cup arm with a ball end, and a bracket with a receiver for the ball. Snap the bracket and arm together, this can take a little effort. mount the disk to your dash in a place that doesn't obstruct your view of the road. then place the arm/bracket on the disk and push the lever down creating suction to hold the mount to the dash.
Another option it the beanbag dash mounts that hold the arm without sticking to your dash.
If this answered your question please check +. If not please elaborate on your queston
Apr 26, 2010 | Garmin nuvi 255W GPS Receiver
Can't assemble suction cup mount that came with Nuvi 350
They fit tight together. Sometimes you need a little force.
Sep 13, 2009 | Garmin 010-10723-03 Suction Cup Mount...
Garmin nuvi 360 suction cup knob issue
If the end of the cradle has a ball,and the cup has
a round part, just push the ball in, yes it does go in hard but should be ok. If it makes you feel more
comfortable, you can put a drop of water on ball and wipe it around, once it dries, it wont slop around.
Apr 09, 2009 | Garmin 010-10723-03 Suction Cup Mount...
Installing Garmin 350
It should be a round hole with three little notches, just stick it in and push (flat surface required!) Then there is a lever on the suction cup to **** it against the windo, just snap close that when you're sticking the hip joint into the socket!
Jun 04, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
65 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
