Question about Nikon EM 35mm SLR Camera
Which end of the battery clip in the Nikon EM is positive?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
The positive end goes first into the camera, the negative end is at the base of the clip. With the batteries in the clip, the + on the top battery should show.
Posted on Aug 30, 2010
Replacement battery for nikon em camera
The EM takes two LR44 or 357 or equivalent batteries.
Sep 02, 2012 | Nikon EM 35mm SLR Camera
I have put the batterys correctly in my em and the light wont come on, the silver clip it pushes against is perfect so its not that
Had the same prob but there was a build up of stuff on the battery terminal...just scraped it off
Feb 14, 2011 | Nikon EM 35mm SLR Camera
My camera won't charge at all
hi chelsea..... You may need a new battery but to be sure do this:
1. turn camera off.
2. remove battery.
3. clean battery contacts in battery compartment and on battery with the eraser end of a common pencil. scrub em clean.
4. Return battery and charge it.
IF the battery doesn't take a charge then take the camera and charger to a camera shop and have the battery and the charger each checked out. Joe
Feb 13, 2011 | Nikon Coolpix S3000 Digital Camera
We put new batteries in a Nikon EM and the light does not come on when battery is check...they are in correctly. Does anyone know how a light meter can get broken?
The battery check is by pressing a very small silver button on the top plate by the shutter release and the little red light come on right? there is only two small button batteries in the EM but without them it's a brick. So look inside the battery compartment and at the bottom you will see a spring piece of metal which the batter makes contact with. If it is corroded then you will have to clean that off to make contact again. Take a new pencil with a new unused red rubber eraser and form a piece of sand paper over the end of the pencil and tape it securely. Lightly twist the pencil back and forth between your fingers to sand off the corrosion, make it shinny. Blow out the dusty dirty stuff with a puffer make sure the batteries are installed correctly. Yes I know you said the batteries were in the right way install the batteries check wiht the battery test button. Also don't forget the EM is a totally battery dependent camera for the meter AND the meter will not work until you have the frame counter at frame # 1 and beyond. My Nikon EM has been slightly modified yours might not be the same but I can close the back and advance the lever trip the shutter and again until it reaches frame one and then the light meter works. Cheers great little camera hope you get it working
Jan 21, 2011 | Nikon FE 35mm SLR Camera
My nikon em camera's flash won't work even though i just put in new batteries. the ready flash will not light up
Having received no response to my latest queries in over a month, I assume this is no longer a problem.
Jul 19, 2010 | Nikon EM 35mm SLR Camera
My Nikon EM got flooded. Is there any hope for it? Or should I just sell it online?
The EM is an electronically controlled SLR so is usually a complete write off if flooded. Many spares are no longer available and most professional repairers would refuse to attempt a repair due to the very high risk of the camera being returned due to additional failures during the repair warranty.
By all means sell it, but please do the right thing and describe it honestly as a spares or repairs model. But think before you do so as unless in perfect working order it has a very low resale value: you may end up paying more in seller fees than you get for it.
Mar 17, 2010 | Nikon EM 35mm SLR Camera
My meter won't work and i just replaced the
Clean the contact inside the camera and the battery cap with a pencil eraser so that the areas that touch the batteries are clean and shiny. Make sure the batteries are placed in the cap so the positive side is up.
Jan 21, 2010 | Nikon EM 35mm SLR Camera
My meter won't work even with new batteries?
I have Nikon EM myself and I have an issue with meter myself. First, the camera won't start metering unless your film counter is at 1 position. So, you have to advance couple of frames in order to have the camera start metering. Second, my unit will show metering information when I press the shutter half way IF I have not advanced the film to the next frame. As soon as I advance the film and ready to take the pic, the meter needle drops and won't show any information. This is caused by the aperture arm of the camera dropping a little bit from it's initial position as soon as you advance the frame. Funny thing is that the camera will continue to meter and make correct exposure, just without the information displayed.
Aug 06, 2009 | Nikon EM 35mm SLR Camera
Film rewind crank stuck in up position nikon n2000
Move it a bit (some half circle)back and forth. The slot may be in wrong position related to the roll inside. It should click in when you get the slot in right angle.
Aug 02, 2009 | Nikon EM 35mm SLR Camera
Nikon EM (1979?) Won't wind film, photos don't come out
Not necessarily. The EM has an M90 setting which will fire the shutter at 1/90th of a second. The meter is inactive on this setting. It was put on the EM so that if the batteries fail, you can shoot at 1/90th and take a guess at the exposure. There is also a small button (blue or chrome, depending on the production run) which lights up a red LED if the batteries are good. The light meter doesn't work until the frame counter is at 1 or higher. Before the #1, the shutter will always fire at 1/2000th of a second to speed up the film loading process. You can tell that the meter is working by observing the meter's scale/needle on the inside of the viewfinder. If it is pointing out of the red zone, it's OK to shoot (proper exposure). If the needle is in the red zone (indicating under or over exposure) the camera will "beep" as an audible warning. Check the battery condition first.
Mar 16, 2009 | Nikon EM 35mm SLR Camera
Nikon EM 35mm SLR Camera Logo
138 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
