Question about HP DL180 G6 (487502001) Server
After installed Windows 20033 the DVD fail, is not recognized please help me. I installed the last firmware , I don't see change. I don't see the DVD on Windows 2003 System .
    Scholar:
  • 106 Answers
1. go into the bios
2. advanced options
3.hard disk configuration
2. select sata: compatible
Posted on Sep 02, 2010
Hello. My Name is Simon. I have a hp670s laptop with tsst corp Ts-l633l cd/dvd player. I have some problems with it. It doesn't want to read the dvd-s. I tried to change the firmware, but it writes...
Hi Simon,
DVD(-) are better suited towards standalone DVD recorders and TV units. DVD (+) are better suited towards your PC needs.
However, that being said, there's no reason your writer shouldn't recognize and write to them.
Some simple steps are:
1) clean your laser lens - alcohol and a q-tip work best for this, and you'd be surprised how often this will work.
2) burn your DVD's at a slower burn rate - if the problem is with reading discs, try burning them slower. If the problem is recognizing the discs altogether,
3) Make sure you have the current drivers/firmware for you disc drive. Firmware updates may enable the use of DVD(-)'s and drivers may be required.
4) You can attempt adjusting the POT settings on your laser, as well, with the caution that this may or may not make it worse, or just break the drive entirely.
If all else fails, get a new drive. DVD writers are cheap and easy to replace in a laptop.
May 11, 2011 | Computers & Internet
HP DVD writer 1140D doesn't recognize DVD's thinks drive is empty. Research on driver versions shows it's using Microsoft drivers. I would like to have the HP drivers to download that came with the DVD but...
all dvd writers have drivers on windows...and are installed automatically when windows is installed..If it started not to recognize dvd-es ...specially the ones burned in data format with multiple movies (avi ) ..even burned on it ...but sees the original ones..or sees the cd'es ..than the issue is with its lens ..and either you need a cleaning disk to clean it up ..or it is gone ...and need to be replaced..I personally have to do with something like this sand tried to update firmware ..installed original driver from the support site ,,and all the same ..Clean the lens and see how it is behaving ..and if it does the same ..just replace it ..cause they do have limited life time..otherwise you will end up with a lot of frustrations and no results...
Mar 18, 2011 | HP DVD1140i 22x Pata Multiformat Dvd...
I have an NEC ND-6750A installed in an HP Pavilion ze5570us laptop. I installed it after the original cd drive failed. Windows recognizes the drive but considers it a CD-ROM drive with no DVD...
did you buy this off of eBay? this unit may need to be "flashed" so to speak. the term is firmware upgrade. the HP website has this and i have supplied the link for you. here is thre link for the firmware update:
http://liggydee.cdfreaks.com/disclaimer/en/6750a/261_orig.zip.html
windows should not only recognize it but should reload the drive with the correct parameters.
Feb 21, 2011 | NEC ND-6750A DVD RW Dual Layer Burner
I Firmware problem!!
check the jumpers are on master slave or both on CS Cable Select
Jul 15, 2010 | Dell Dimension 1100 PC Desktop
Hi: My computer is not recognizing my ts-h492a
Please go here and download the live update from Samsung. This software is designed to automatically update you to the latest firmware via the internet. To get this service, customers have to install the Firmware LiveUpdate program on their computers.
Please download the live update full version if you have not used this software before. See link.
http://www.samsungodd.com/Eng/Firmware/liveupdate.asp
Simply follow the instructions as given and your software will be updated to the latest version required to run your CD/DVD writer with your computer.
Hope this helps. If so please do leave a vote for the solution. Thanks.
Mar 01, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
Model #GWA-4164B DVD Writer does not recognize any disc Cd or DVD. computer sees the drive when you install a DVD it tries to read and fails . Try to explore it indicates please insert a disc. Firmware is...
It sounds as if the disc drive laser has died, when they burn out they will not recognize any disc inserted. fortunatly a replacement drive is relativly inexpensive to replace.
Aug 24, 2009 | Hitachi Computers & Internet
Optiarc CD-RW CRX880A Reads CD/DVD, FAILS to write intermittently
To my knowledge, that is a firmware issue. Go to http://www.sony-optiarc.us/en/support-service/downloads/fw_cd-writer-dv-series3.htm and click the last link, which is the firmware download.zip for your updated firmware. Install that, and try again. If you have any problems, repost and i can try helping again.
Sean Huffstickler
Jun 03, 2009 | Microsoft Windows Vista Ultimate Edition
HP DVD 1040i
I would email or call hp support and ask about this as there should be a firmware update of some description.
Also re install latest chipset drivers and maybe adaptec aspi drivers ?
Apr 17, 2009 | HP DVD1040i 20x Super Multiformat Dvd...
DVD RW DVR-K16 does not recognize blank DVD-R
I have a Pioneer DVDRW DVR-K16, in a sony dv81114Notebook. Running Windows XP. It cannot play dvd's and cd's, It will recognize blank CD-R's but when I insert a DVD-R it say's no disc installed. I have firmware version 1.15.
Nov 26, 2008 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Dvd rom
Hello
To isolate the issue please perform following steps.
Click Start and select Run . In the Run box type devmgmt.msc and press enter. This will open Device Manager.
Click on + sign next to CD/DVD drive and right click on all the devices listed unde CD/DVD drive and select uninstall. Then restart the notebook. This will automatically install CD/DVD drive drivers. This should resolve the issue. However, if the issue persists please download and install following dougnox patch if you are using XP operating system.
http://www.dougknox.com/xp/scripts/xp_cd_dvd_fix.vbs
Please make sure that if you are using XP then only try to download and install above dougnox patch.
This will resolve the issue.
Thanks
Regards
If you think the above information is helpful then rate me.
Jun 20, 2008 | Computers & Internet
HP DL180 G6 (487502001) Server Logo
101 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
