Toshiba Satellite A100-S8111TD Notebook Logo
Posted on May 06, 2008
Toshiba no sound after reloading initial system
I relaoded the faCTORY CD, ALL SEEM TO BE THERE, BUT i HAVE NO SOUND.
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on May 09, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
2945
Points
23
Go to toshiba web site. select the laptop model and download the latest sound drivers for it. this should work if not replace the systemboard.
1helpful
This the screen i see...how do i factory reset my toshiba satellite m55-s3292?
First, make sure no usb thumb drive, floppy, external drives, or CD disks are in the computer and restart.
If the error appears, then the boot loader on the computer is corrupt. You will will have to reload/repair your operating system.
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
My computer was destroyed by viruses and i need to do a factory reset. How do i do a factory reset for a toshiba satellite?
The only way that you can do a factory reset is to use your system restore disk to reload your operating system. Either you received these disk when you purchased your system or the files where stored on a separate partition on your system and you needed to create them...
I do not have disk for my emachine I forgort my password and I want to restore to original factory setting I did this once and pressed I think F10 but can not find paperwork Can anyone help
If you have a back-up on your computer you should be able to press CTRL F10 or F11 depending on your model. If you do not, you will have to relaod it yourself or have someone reload it for you.
IBM Lenovo t60, the logon user interface DLL
To wipe and reload you don't actually have to log in. You just need to set first boot option to CD, insert the XP disk, and reboot the computer. All the steps from there on out are explained on the screen.
I hope this helps :)
2answers
Toshiba 5005-S504 recovery problem
Unfortunately , you are going to have to call Toshiba.
from the sound of it your recovery disks are failing and they have already formatted your harddrve
My ipod 30g turn on then showing the apple then crashes
Put you ipod in disk mode
Press and Hold the Menu and Center buttons
when the apple appears quickly switch to
Press and hold the Center and Play/Pause buttons.
If it goes into Disk mode, connect it to your computer and
Restore your ipod to factory settings.
Relaod your music
Warning: Restoring your ipod will delete all your music and content and reload the operating software.
1helpful
2answers
No driver, just camera
Hello Hello_28
Click Here for driver downloads
Answer the prompted questions.
Any problems, let me know.
Mike
2answers
Factory restore
On a laptop there is no factory setting reset option (unless you mean bios reset ). To get the laptop back to the initial 'as new' condition you need to re-install the system using the recovery disk on startup. Put recovery cd 1 inside laptop cd drive and restart the computer. Follow instructions for complete restore.
If you do complete restore you can lose all your data.
Here is also the user guide :
Satellite L350 Series User’sGuidecheck page 150 onward for other system setting problems
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
