When playing a divx file via usb port on my lg ht321 dvd receiver, and lg tv, the audio is out of sync. the audio is perfect when watching the divx file on laptop. why is this and how can i fix it?
SOURCE: HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Posted on Feb 24, 2008
  • 50 Answers
SOURCE: can't play divx files via the usb port i.e. when using a memory stick
No you can't Usb only supports Jpeg and Mp3
Jay
Posted on May 21, 2009
smarthome2
  • 1114 Answers
SOURCE: Receiver very low when watching tv or dvd
It's just "Digital Audio" vs "Analog Audio" You can use the "Volume Offset" function in the receivers "Main Menu" to compensate for this. Go into the menu then go to audio and or input settings and you can adjust the offset and lock it in. If you still have a problem, post a comment and I can help you some more. There is not a "problem" it's just the way the audio is transmitted. Like when your watching TV and a commercial comes on and BLOWS you out of the room. That's going from clean digital to noisy analog.
Posted on Aug 09, 2009
dunnbiker
  • 8546 Answers
SOURCE: Marantz SR4003
Hip shot: No one let's you record digital audio onto analog equipment (yet).
On looking at Page 26 of the manual, that is verified. (See the Notes). Use only the analog audio and it will probably work for you. The A/D switch decides which you will use.
Posted on Jan 28, 2010
  • 5389 Answers
SOURCE: how do i connect my HDTV to my YAMAHA HTR-5930
The simplest for the movie would be to connect the Optical digital audio out of the TV (above the VGA port) to the Optical Audio In on the receiver. You will need to get this cable from any store that sells TOSLink cables. The manual for the TV is available here: http://www.lg.com/uk/tv-audio-video/televisions/LG-led-tv-42LE5300.jsp . The manual for the receiver is available at the Yamaha support page if you are a registered Yamaha customer: http://download.yamaha.com/search/product/?category_id1=16445&&category_id2=16446&product_id=1060939 .
For the XBox, I'd suggest the same connection if you are using HDMI out on the XBox. If you are using component or composite video, route the audio cables to the receiver's RCA audio in.
I hope this helps.
Posted on Feb 22, 2011
My LG DP122 will play some AVI files from a USB device but not others.
figured this out, lg dp122 uses DivX Home Theater profile, so the technical specs of the video must match that.
Those specs can be found here: http://www.divx.com/files/DivX-Profiles_Tech-Specs.pdf
Jan 23, 2013 | LG DP122 DVD Player, Multi Format...
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
Toshiba SD2010 DVD player
It can't read the files on the USB, wrong format.
Jul 14, 2017 | Televison & Video
I have a 50' lg plasma, when i plug my hard drive in through the usb port it wont recognise the files, i have a lg led lcd that i have no problems with so what can i do to make it work on the plasma?
tv wont read your files only pictures doesn't have the software to read divx and other video files get a dvd player that has a usb port like http://www.newegg.com/Product/Product.aspx?Item=N82E16882136231 or any other brand I have a pioneer Pioneer DV-310-K Slim Multi-Format DVD Player Featuring USB and DivX Playback but out of stock hope this helps happy downloading you might also have to format your harddrive http://forums.afterdawn.com/thread_view.cfm/523631
Sep 12, 2010 | Audio Players & Recorders
Picture sides cut off when watching avi files
My new LG LCD is not syncing the video and audio when playing avi movies on either USB stick or HDD.
Dec 28, 2009 | LG 37LC5DC 37 in. LCD Television
LG HT762 DVD Player won't play divx anymore?
Try to unplug the player for a few seconds and then plug it back. It should work again with the DivX files. I had an identical problem and since then, it works just fine.
Apr 02, 2009 | Televison & Video
Playing DIVX on an LG LH-RH3690 DVD recorder
You can not view from the USB, since the USB port on the DVD player is ver 1.1. The transfer speed is to slow to watch a movie. Alternatively you can copy your movie from your flashdrive to the harddrive and watch from there. You will see what I mean with slow speed when you copy the movie. It takes ages.
Sep 11, 2008 | Yahoo YDP305 DVD Player
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
USB Port
I am not getting any sound from my koss model ks3101 through the speakers
May 30, 2008 | Philips LX3750W System
61 people viewed this question
 Grubhead
Grubhead
