Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
How does one resolve flashing"dl" code for Whirlpool Type: 580, MOD: WTW7300XW0?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 28, 2010
Wondering what code F-- means on cabrio whirlpool topload mod. wtw66005w2 Thank You
Is there a number after the F code?
Thats ok heres what the code means: Whirlpool Cabrio Washer Fault Codes.
Means primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part.
Hope helps.
Aug 03, 2011 | Washing Machines
I have a fault code of "F DL "
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Jul 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error Code DL and it won't run
Hi
Thanks for using FixYa. Error DL indicates door lock failure and it flashes when either the door lid is not closed completely and/or the Machine/motor control detects door lid switch is open. To resolve this issue you'll have to check the door lid/switch if it's fine then replace the machine/motor control however, the issue seems to be with the door lid. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio won't spin
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation. ➔ Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction
its SD not 5D
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify: ➔ Load is bunched or twisted around agitator. ➔ Excessive detergent usage. ➔ Basket cannot engage during drain step. ➔ Mechanical friction on drive mechanism, not allowing basket to engage.
Jul 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer is flashing f and dl and isnt draining correct.
This is joyce
First of all unplug unit from wall to reset. leave unpluged for 1 min. then replug back
check to see if you lines are not crimped where your water goes out of machine. if this dont work to get your codes go to web site whirlpool.com and type in your model # and download your documents and find your codes and then you can go from their, I have the same thing you have and believe me I have had my share of problems with mine, but nothing like you are having, thank goodness I had exstended warranty for 5 years, it is exspensive to work on these units. dont try to work on them yourself they are all high tech. if you need help finding someone to work on your unit just email me.
thanks
joyce
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool cabrio washer keeps flashing code F50
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
Jan 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
254 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
