Question about Refrigerators
Upright Frost Free Freezer
I could not locate a fan switch on the door. However, the fan on the inside of the freezer located at the top is not running and that is where it is warm. Also, on the outside of the freezer below the door is a red alarm light that is on. That is probably just an indicator that there is a problem. Any ideas?
  • 828 Answers
If there is no switch the problem is more than likely in the fan motor itself. Check for ice around fan blade. If there is no ice which could stop the fan rotation replace the fan motor.
Posted on May 07, 2008
Model EEV-163F Whirlpool Upright Freezer. Defrosted this week, already seeing ice buildup. Freezer is cold and appears to run fine, but frost buildup seems excessive this quickly. Frost throughout
This freezer is not frost free. Being an upright limiting the amount and frequency of opening the door will reduce the build up of ice. Ice is expected and depending on humidity and quality of seal around door affects the amount of ice.
Using a thin ribbon check the seal integrity around the door. Confirm nothing is prohibiting the full closure of the door.
Adjust door if necessary. Replace seal if defective. Freeze open unsealed items in a frost free freezer before locating frozen food in this unit.
These units are likely located in the garage where the humidity is high. If used only as needed planning transfer between this and the kitchen unit frost can be minimized.
Being a conventional freezer not frost free freezer burn is less likely and frozen food will not dry out as quickly. Confirm that the freezer maintains about 0 degree F.
This unit is likely more efficient and will maintain the food frozen longer in the event of power outage.
Hope this helps?
Jun 24, 2017 | Whirlpool Refrigerators
Frigidaire upright--"Hi temp" warning light on door. Don't know why freezer temperatures are so high (into 30s), food is thawing. Electrical seems to be fine. Have not noticed problems with door. New...
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
Jan 11, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
ALARM WENT OFF ON OUR KENMORE UPRIGHT FREEZER. HOW DO WE GET IT RESET. WE HAVE PUSHED THE BUTTONS BUT RED LIGHT IS STILL ON AND FREEZER NOT RUNNING. THE PROBLEM STARTED BECAUSE WE DID NOT GET THE DOOR SHUT...
The light and alarm will remain active until the temp in the freezer is "normal" or satisfied. You should be able to push & hold the button (if electronic) until it stops. If it is a manual switch, they are usually located at the bottom of the cabinet below the door.(some are located inside the unit on the wall as well) It may be a "rocker" switch or part of the actual indicator light. Good luck
Sep 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Mar 27, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have an upright frost free freezer that is not working properly. It seems cold at the bottom and warm at the top. Would this suggest the fan motor needs to be replaced?
Your problem could be in the fan switch which is located someplace on the breaker strip around the door. If you push in on the switch and the fan runs the fan is not the problem. If you have frost on the back wall you may have a problem in the defrost system.
May 06, 2008 | Refrigerators
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Oct 12, 2007 | Maytag Freezer MQU2057
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
