Question about Black & Decker Saws
Is an electrical diagram and capacitor size for the one horse induction motor for my 8 1/4" portable table saw available?
5 Suggested Answers
  • 86 Answers
SOURCE: ryobi bt 3000 table saw belt installation diagram
The BT3000 actually has TWO v-belts! Here's a link at the end of this solution to an exploded diagram. Basically you have a major disassembly, but it really isnt that complicated.
More great info on the BT3000 is available from the web site http://bt3000.com/
I have a BT3100 saw, and it is a good tool, but does require attention in maintenance procedures, but Ryobi did outline the necessary steps in their manuals. The above website also has the owner manual if you need one.
  1. Unplug saw
  2. Remove the blade
  3. Lower mechanism all the way to the bottom
  4. Flip over saw and lay on it's top
  5. Remove the blade guard panel opposite the motor
  6. Unbolt the motor assembly and remove the belt cover
  7. Replace the broken belts
  8. Re-assemble (be careful not to cross-thread the bolts in the aluminum housings!)
http://bt3000.com/Manuals/BT3000-Parts-Manual.pdf
Posted on Mar 22, 2009
efs_perpends
  • 1996 Answers
SOURCE: I have a Task Force Heavy Duty Folding Saw Horse.
I can't tell you whether parts for that are available or not. All I can find is a link to the manufacturer, but you could contact them and check, if this is indeed the same model you have. Link here.
Posted on Aug 25, 2009
  • 8404 Answers
SOURCE: Ryobi 10 in Portable Table Saw modl #BTS12S won't turn on
Look for a trip switch on the saw motor
Posted on Nov 02, 2009
  • 8404 Answers
SOURCE: i need the wiring diagram for my 10 table saw
Im guessing ... the motor is 110 volt AC (AC dont care if it is coming or going) ... find the two terminals in the motor and hook the wires back up. If it HAPPENS to be incorrect, the saw will run poorly or the overload will trip.
I wouldnt be afraid to use this method on my craftsman table saw.
Posted on Nov 03, 2009
Capacitor ?
On table saws with induction motor there can be a capacitor but also a centrifugal starter (not oft buts possible) unit inside the motor with a capacitor . if the saw is buzzing , yes there is a capacitor problem, they rarely shorting, between 20 and 60uf or more are neccesary depends on size of motor.
If you can measure with an ohm meter then you see thats sucking on the battery of the multimeter, and turn the polarisation after 5 seconds the you see its unloading in negative way , if there is no response on the meter or its bulged or whatever replace it .
Mar 01, 2016 | Saws
My delta table saw keeps blowing the circuit breaker on the saw. It does not sound quiet and smooth like usual. I got a good blade its on tight what could this be?
a bad centrifugal starter or inside capacitor and or the electric field if an old type with induction motor , but if it has carbon brushes in the motor instead of an induction motor the commutator on the armature short brushes or a bad bearing(s) on the motor or other gearbearings on the saw drive are worn , it must have a smooth turn if turn on the armature if remove the field /motor house.. look in the motor if running at the end if the carbon brushes you see are make to much sparks a worn bearing without the balls or bad armature collectors or electric field . watch if the bearing is worn by blue hot it can have melting the seat in the motor house replace it all.
Mar 28, 2015 | Delta Saws
Need electric motor for model #113241680. what is the rpm and horse power.
here is the sears parts for your saw
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-113241680/0247/0744600?pathTaken=
looks like they dont sell the motor any more. as long as you have the spec plate on your motor you should be able to match up something from a parts house or anyone that sells electric motors. in my area its Granger
Dec 28, 2010 | Craftsman 10" Table Saw
For about six months my bosch table saw has imtermitent motor problems sometimes it works other times it doesn't now the motor is smoking how do i get a new motor
Parts diagram is here.
Looks like you can't just buy a new motor.
Service center locator is here. Click the Portable Electric & Battery Power Tools button. Put in your zip code and you can call around to see who can fix you up the quickest.
It looks like warranty on this saw is one year. Depending on how old your saw is, it may even be covered under warranty.
Jun 09, 2010 | Bosch 4100 09 10" Worksite Table Saw...
Craftsman 8'' direct drive table saw only hums
Safety note - make sure to disconnect the power from the wall before you start checking this stuff.
Odds are it's one of four problems. The first is easiest to fix and most likely. The other three are probably best dealt with by an electric motor repair shop.
1) Start capacitor failure. Capacitors age and eventually die. If you know a bit about electronics, you can disassemble your motor, remove the capacitor and test its capacitance (it will have a label identifying its capacitance in microfarads (mfd)). If the capacitance measures way lower than the label says, buy a replacement of the same capacitance (try Granger) and you'll be back up and running. Be careful though, capacitors are batteries and they can give you a pretty good shock.
2) Shaft locked up. If you can turn the pulley on the motor by hand, this isn't the problem.
3) Start switch failure. This switch is inside the motor. Since you're asking this question. you should probably get a repair shop motor shop to handle this.
4) Winding failure. Since it's been working fine, pretty much all that would happen here is a wire coming loose inside or it might have burned up. If a continuity check on them fails, the windings are probably at fault.
Jun 07, 2010 | Craftsman 10" Table Saw
I have a craftsman radial arm saw 113.23100. The motor pops fuses. I've troubleshooted it down to a contact switch in the motor. The switch is wired to the capacitor. It is activated by a spring loaded...
these motors are induction motors and the centrifugal assembly you mention is used to give the motor extra power on start up once running its not used you should test the capacitor is ok. it could be the motor windings are on the way out and you will need to check the coils resistance in the motor to rule that out
Apr 04, 2010 | Craftsman 10" Table Saw
New saw purchace
Two main problems will be space (hence your plan for a rolling cabinet) and rust. Get a contractor style saw (which has the motor under the table instead of hanging off the back) and has an aluminum table (instead of cast iron). Unless you aren't going to put cars in your garage anymore, I wouldn't worry about being able to cut sheet goods on the table saw. There are simple solutions using saw horses, clamping a guide board on the sheet and using a circular saw that are much more flexible and surprisingly accurate. This takes up a lot less space and is easier to control than doing this on a table saw.
Jan 11, 2010 | Dewalt DW744S 10" Portable Table Saw with...
My table saw stops after a minute or two i replaces the capacitor and still does the same the breaker pops out
This means it's drawing high amp. Could be just packed with saw dust, getting hot. The breaker is probably thermal. Clean it up good. If it still trips, check for name plate current on motor and test.
Jun 22, 2009 | Delta 36-716B 10" 1-3/4 HP 120/240V...
DW744 table saw
Balde movement up and down? If so, that would suggest worn bearings in teh gearbox. If they are worn there then they might also be worn in the motor. If this happens the armature will float up and down causing it to rub against the stator. You may be able to get the bearings sorted without needing any new motr parts. I beleive this saw uses an induction motor so beware if it does need replcing you might want to be sitting down when you get the quote.
Oct 19, 2008 | Dewalt DW744 Factory Reconditioned Heavy...
Sears table saw
DO YOU WANT TO SELL IT ?
MY EMAIL JCD339@AOL.COM
Jul 21, 2008 | Kitchen Appliances - Others
Saws Logo
23 people viewed this question
Top Black & Decker Saws Experts
Jason
Mike Carew
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
