Have 3.5 ton scroll compressor, single phase, that will not run. Checked start, run, common windings all ohmed ok. Checked for case ground/short, none detected. Replaced contactor and capacitor with new. Still will not run. Force contactor closed to energize leads to comp and voltage is there, but comp will not kick off. Checked amp draw on incoming line is 4.5 due to only condenser fan running. If comp was locked amps would be very high and if internal wiring were shorted it would show open. I have consulted other techs who also are scratching their heads on this one. There is no external reset, but possibly an internal one that has failed? High pressure and high temp switches have been bypassed. The comp should start as it is direct wired to contactor leads with safetys disconnected.
    President:
  • 1,796 Answers
Hi!!
Wire your compressor the following way, run new wires if needed, forget about bypassing sensors, check electrical terminals to be tight and clean.
1. Have L1 going straight to the compressor's "C" common terminal, 2. L2 to the Capacitors "C" Terminal (if dual or either one if single capacitor),
3. The "S" Start terminal on the compressor to the "Herm" (If Dual Capacitor) or the "Free" terminal (if Single Capacitor);
4. the "Run" line from the compressor goes to the same terminal on the capacitor as the L2.
If the compressor starts, let it run for a couple of minutes to find out if it it is overheating. If the compressor do not start or starts and overheats, replace the compressor.
Keep me posted!!
Posted on Aug 27, 2010
I hear it starting up, then after few seconds it stops and the most left right light (ref temp 5) keeps blinking on and off. Please help xx
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. ( if in series with the windings)
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
God is so good: so this is why I give free advice so please thank him not me.
May 22, 2015 | Refrigerators
Compressor cycling on and off
May 17, 2015 | Refrigerators
My fridge starting after some time stopping and not starting it self unless switch off power supply and then on it will again in auto
May 01, 2015 | Refrigerators
Clicking noise in bottom of drawer refridgerator. Power and lights go on and off
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Mar 25, 2015 | Refrigerators
Hi I have a Westinghouse 614 fridge/freezer compressor is not working and l found that starter relay was faulty changed it but still no go. there are two wires one blue and one white l believe blue was...
I believe the actual colors should be re for run windings and white for start capcitor and green or brown or black for ground.
Mar 02, 2015 | Westinghouse Refrigerators
Intermittent clicking noise on Maytag side by side built in fridge freezer
Feb 16, 2015 | Maytag Refrigerators
Why refrigerator compressor will not start?
Feb 14, 2015 | Kenmore Refrigerators
Ge model HSS25gfPH
Jun 25, 2014 | Kenmore Side by Side Refrigerator
How to troubleshoot refrigerator compressor
May 26, 2014 | Samsung Refrigerators
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 29, 2017 | Carrier Heating & Cooling
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
