Question about Belkin N1 Vision Wireless Router
Where is located the ip adrres in my router. thanks
I can't find my WEP Key for the SB5101N Router. I tried the numbers located on the router itself, none of them have worked.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 14, 2011 | Arris SURFboard® SB5101 Cable Modem
How do I locate my "wpa key"?
Jun 21, 2011 | Computers & Internet
I would like to know the adrres and phone number of the canadian embassy in toronto
If you are in Toronto, and need renew your Canadian Passport, see: http://york.cioc.ca/record/MKM2266 for location information.
Canada maintains embassy offices in many countries _OUTSIDE_ of Canada:
http://www.learn4good.com/travel/canada_embassies.htm
Apr 02, 2011 | Computers & Internet
I have lost my network key password. Do I have to reset the whole system again ? Can I locate it on my computer ?
Feb 10, 2011 | Buffalo Technology AirStation G54...
Just need to know where the network key or WPA key is located on my belkin router
Jan 14, 2011 | Belkin (F5D7230-4) Router (587009)
How do I install a wireless router
Connect it to your modem. Locate the IP address for the router. It should either be on the bottom of the router or in your manual
Open your browser and enter that IP address into the address bar. You will also need to locate the default user-name and password, should be with the IP address. Enter that information when prompted.
Locate the wireless settings in your router admin area, enable wireless output, set security settings (remember to write them down) and connect your computer to your wireless network.
Sep 21, 2010 | Computers & Internet
Were is wpa located on the router
http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings then Security then WPA security .It is your password to connect wi fi.
If it is in * or # format then add new password then save settings and restart router.
Then you can connect your wi fi network with that code.
May 21, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computer cannot locate Belkin N router
First of all, plug in the router as you always did to the old computer. Follow the steps below
Click on Start --> Run . type cmd in the command prompt, type ipconfig. Make sure the ipaddress you see is in the 192.168.... series. If you dont see the 192.168 series IP address, make sure you dont have a static IP.
Thanks
Ranjit
Aug 11, 2009 | Belkin N1 Vision Wireless Router
Zyxel p660r
connect a computer to the router, open your IE then type http://192.168.1.1 this is the default IP address of the router, it you have changed it, use that ip address. if you cannot locate the router IP, type IPCONFIG in your command prompt and you "default gateway" is the router IP address
Aug 10, 2008 | Zyxel Prestige 660R Router (P660R)
Nortel 1050 connecting a VPN to a BSR222
Does the 1050 support tunnels to the BSR222 with dynamic addressing?
Oct 24, 2007 | Computers & Internet
Belkin N1 Vision Wireless Router  Logo
14 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
