600G external drive is not seen by XP. Was working fine.
    Genius:
  • 2,785 Answers
Check in another pc
Posted on May 08, 2008
The hardrive flashes blue but cannot be seen by my PC. I have windows XP
did you try a different, system to plug the drive into?
if the drive works on other systems , then your old xp has issues.
id get off XP , as MS support ends soon.
The XP OS, goes dingdong when you connnect any USB device.
if the USB is bad on PC or the External drive is dead.
so try the drive on one more PC. and now you know which end to work , all this is easy , try another PC.
Oct 02, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
My DEll PC runnig XP SP3 cannot
Yes the drive is compatible with XP. I have seen a slightly higher than normal # of problems with their 1TB models so this may just be a batch problem. My suggestion if there's nothing crucial on the drive is to return it an purchase a different brand.
If it's not returnable you'll have to settle for asking Buffalo for a replacement. If there's crucial data on it you will need the help of a recovery pro. In that case, comment back with your Country, State and City and I will point you to a nearby Recovery facility.
Hope this helps FixYa,
Chris
Jul 16, 2009 | Buffalo Technology 1TB DriveStation...
External Maxtor Basics 1Tb XP/Vista
its the drivers not installed on vista.. ur drive is fine
Mar 14, 2009 | Maxtor Hard Drive
Install Xp on Acer Asprie 5735z
I'd reccomend backing up data and formatting your hard drive. Then install XP from disk and put data back on hard drive. You could use external hard drive or jumpdrive. It stands to reason that SATA works with XP, because the new computers I have seen have SATA and XP working conflict-free.
Feb 13, 2009 | Acer Computers & Internet
Archos not seen by pc
This can happen to any external drive on a pc. If the Archos is set to PC Hard Drive mode, then plug it into you PC and click Start, click Run, type compmgmt.msc, and then click OK.
In the console tree, click Disk Management.
You can now allocate a drive letter to the Archos.
If you cannot see your Archos in this window, then you may have a dodgey usb cable.
Dec 30, 2008 | Archos 605 WiFi Digital Media Player
Windows XP SP2 will not boot after installing new SATA hard drive
Your system thinks the "second" drive has precedence over the first ( your boot drive ) try switching the SATA cables between the two drives. There also might be a BIOS setting under Boot Order, sometimes you have to drill down to get to it for a particular drive.
Dec 25, 2008 | Microsoft Windows XP Professional for PC
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Jun 11, 2008 | Belkin (F5U233-APL) 4-Port USB Hub
Freeagent tools is not working
With your XP problem..
Goto My Computer and right click.
Select Manage
In the window that opens select Storage and then Disk Management.
Your drives will be there, but need to be mounted. Right clicking on the drive will give you your options etc.
Your Vista problem I will have ot contemplate, though it's probably a software compatability issue more then anything.
Try running the EXE file under XP compatability, or check the website for an updated version. Be sure to get the 64 bit or 32 bit version as required.
Apr 21, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
