Question about Dirt Devil Vibe Deluxe MCE6680V Bagless Upright Vacuum
Water will not spray out of the bottom of the vacuum i have checked all the connections and they seem correct.
  • 4,102 Answers
Hi this is a very common problem, whats happened is the cleaning solution has turned to gel and is blocking the pipe and not allowing the solution to come out what you can try is drain any cleaner out of the container and fill it up with hot but not boiling water and put a couple tea spoons of salt in then leave this to rest for 10min then switch the vac on and try the trigger and see if the water comes out you may need to hold it down for few minutes.
if after doing that its still not coming out then tip the vac up onto its back and have a look at the jets where the cleaner should come out now get a long pin and give the jets a good poke out with the needle doing this should unblock it.
if it dont then its going to need the bottom taking off to get to the hose and so you can squeeze any blockage out but let me know how you get on you may find cleaning the jets gets ot working it does most of the time.
remember when you have finished using it empty the cleaner fluid container and fill it up with warm water then let this run through the cleaner for 3 or 4 min just hold you finger on the trigger and let it drain through the whole vac doing this will prevent it from clogging up in the future
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Aug 27, 2010
Power head is spraying out dust. No particles are going into the water
You can check the belt. If you rainbow belt is broken the power head will seem to spit dirt back out.
May 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
When button is pressed, water does not come out of the holding canister. still seems to have suction, but water doesn't come out to rinse/clean carpet.
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Nov 22, 2010 | Bissell 9200 Upright Vacuum
Bissell, ProHeat, ProTech won't spray water.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
895r
Jul 16, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My steamvac will spray out water
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Sep 20, 2009 | Hoover SteamVac F5914-900 SpinScrub...
System will spray soap, but no water is mixed.
I had the same problem. After 3 weeks of seals belts pump etc. I was ready to give up.
The problem with mine as I suspect with others is the seal on the water tank.
The bottom plastic connector is not high enough to allow the water to flow to the pump.
My solution was to raise the bottom connector 3/16 of an inch.
I did this with a piece of plastic cut like a flat washer or auto gasket material could be used.
The connector must be removed from the bottom by pressing on the tabs. Hope this helps.
Apr 19, 2009 | Bissell 1699 ProHeat Clear View Upright...
The Water will not spray out(it just dribbles) of the shampooer
heatman101
ewrtwy
Nov 27, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1698 Powersteamer no spray
A simple thing to check is make sure the round seal is on the bottom of the tank, it needs to be on the tank not sitting loose in then hole that the tank valve goes into. Could be a problem with the flow indictor cap leaking air. Is the top and the base tight together in the back, sometimes the plastic breaks loose and the top will rise enough that it raises the tank so water won't flow. Your pump may be bad.
Mar 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Feb 25, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
If it seems like the tank does not fit in securely, the round gasket that goes around the valve at the bottom of the tank may have come off and actually be in the hole in the bottom of the vacuum base. It looks like it belongs there but you can pull it out with some needle nosed pliers. After you remove it, put it around the valve on the bottom of the tank, then it will fit into the hole again and everything should seal correctly. Mine was not spraying and would not suction well. figured this out and now it works great again.
Apr 16, 2006 | Bissell 1698 PowerSteamer ProHeat Upright...
Dirt Devil Vibe Deluxe  MCE6680V Bagless Upright Vacuum Logo
107 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
