Question about Microsoft Windows XP Home Edition
Keyboard stuck in upper case
The keyboard on TravelMate 2310 is stuck in upper case and will not type lower case.
My portable keyboard plugged into this laptop types properly.
Thanks for your help
Ann
ann fixya asked me to type my question again my keyboard is stuck on upper case or lower case and not working properly did you solve your problem i tried to reboot but no help caps light is on when i am using lower case and no caps everything is reversed do you know where the function key is someone suggested holding down function key and press f11 but i dont know where function key is i have windows xp and microsoft keyboard please, please help thank you very much starlingbird
  • Judi McInnes May 06, 2008
    I have a Gateway desktop and a Microsoft keyboard and there is no Fn key that I can see. Someone suggested on this website to press Function key and F11 to solve the issue of a stuck keyboard that only types UPPER CASE. Cannot find a function key. Any more suggestions? Thank you very much for trying to help.
Press caps lock and F9 together see if that fixes it
Posted on Oct 27, 2009
    Genius:
  • 1,554 Answers
Function key is marked Fn
Posted on May 06, 2008
  • Karl Whisenand
    Karl Whisenand May 07, 2008
    well you did ask for function key , though thats only on a laptop.I kept seeing the word laptop. my bad.
    try holding down the num lock key 6 sec
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
WHEN YOU PRESS THE CAPS LOCK BUTTON YOU HAVE THE CHOICE OF UPPER AND LOWER CASE LETTERING BUT THERE IS ALSO AN ARROW BUTTON WHICH IS TURNED OFF AND I AM NOT ABLE TO TURN IT OFF IT SEEMS TO HAVE REVERSED MY...
That UP arrow refers to an UPPER CASE letter. If ever you press the CAPS LOCK key, it should turn off, if it does not it means the CAPS LOCK key for some reason is stuck. Try restarting the computer and by then the CAPS LOCK should be disabled.
Please let me know if it helped by selecting YES. Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Jan 31, 2011 | Gateway 2520915 Keyboard
Hello, When typing on my Mo Droid if I want my caps to stay on how do I get that to work.....I tried holding it down but maybe I am not doing it properly?
If you are typing using the touchscreen, the upper-case arrow, touched once, will upper-case the next letter you type and then back to lower case. It you touch the upper-case arrow twice in a row, you should see a green light come on directly over it. That keeps the caps lock on.
If you are using the slide-out keyboard, touch the upper case key once and you should see a triangle underneath the cursor on the screen. That will upper case the next letter you type. To get it to stay in upper case, hit the upper case button again and the triangle should change to a > symbol, point up, underneath the cursor. That should keep it in upper case mode. Don't hold the upper case button down, as that won't do anything. A third press returns it to normal (lower case).
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
I have a Yamaha YPT-400. I walked into the music room to find a 85lb. child standing on the keys to get to a shelf above the keyboard. Grrr...Now, I have a key stuck. How would I fix this?
You have to disassemble the case to get to the keys. They LIKELY stay with the bottom of the case. Be careful of the cables from the upper half of the case to the lower.
I am not sure what type keys you have. If these are the semi-weighted piano type, the spring underneath gets out of position... If they are the silicone dome type, the dome may be crushed and you will have to replace the section that is bad. Hopefully the circuit board under that type is not cracked.
The first type mentioned requires some tricks and for that type you MAY have to remove several keys to assemble them in order. I had to make a little "L" shaped piece of metal to get the springs into place. It took about a 1/4 inch leg to go between and under the key to lift the flat spring into place.
One has to get the tang at the front of the key engaged as well. Certain notes you have to install in sequence as the black keys can block getting a white key in position.
Mar 13, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
I can not get lower case
Check for a light on the keyboard, caps lock could be on.
The caps lock key might be sticking press down on it a few times might loosen it a bit.
Jan 22, 2010 | Acer NSK8458AN Keyboard
How do I fit a replacement keyboard for my acer travelmate 4150
You need to remove the middle cover of the laptop and unscrew a few screw at the lower case. Try the find the logo keyboard at the lower case. I think just this model got screw to remove first to take it out.
Sep 28, 2009 | Acer TravelMate 4150LCi Notebook
Cant type upper case letters
If your caps lock is not working, a best alternative would be to hold down the shift key while pressing a letter and it will convert lower case to upper case.
Sounds like a new keyboard may be in the future for you.
Sep 01, 2008 | Computers & Internet
Keyboard locked in upper case
Try reseating the key board.
Check whether the keys are stuck especially the shift,alt,caps lock.
Hav you spilled any liquid on the keyboad.
Try uninstalling any software you installed for the keyboard and remove it from Device Manager (Click Start-Run-Type devmgmt.msc and click OK).
Reboot and see if that helps anything. Also, check the right shift and make sure it isn't stuck and check the keyboard settings in the Control Panel
Update the keyboad software from the microsoft website.
Pleae mntion the model  number of the keyboard to help us know more about the keyboard.
You can try holding down function key and press f11.
Control Panel -> Regional and language settings -> Tab: Languages,
Button: Details, and add a US Keyboard.
Check this to know the functions
http://support.microsoft.com/default.aspx?scid=kb%3ben-us%3b894513
Check the keyboard settings.
Try using other keyboard to know the keyboard is fine or not.
This will help you i hope.
Good Luck.
Live, Love, Laugh.
May 06, 2008 | Microsoft Windows XP Home Edition
Is the caps lock light illuminated? If so, you might have to hold shift and hit caps lock to turn off the caps lock. This is an option for old typists who came from manual typewriters that you might have turned on by mistake.
Mar 05, 2008 | Acer NSK8458AN Keyboard
Microsoft Windows XP Home Edition Logo
1,452 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
