Water is coming from indoor unit - Heating & Cooling
    President:
  • 3,074 Answers
The drain is more then likely clogged
Posted on Aug 27, 2010
How do i do when the indoor unit start water leaking non stop??
Water leaking depends on 18 reasons. Plz let me be cleared that voltage, amphs, gas pressurer, indoor motor condition, cleanliness of the indoor evaporator coil., etc.
Sep 20, 2014 | Heating & Cooling
What could be causing one of the wall mount units to ice up on a 3 port mini split hp?
Icing is caused by one of two things.
1. The air coming in is too much and has a lot of water vapor in it.
2. The evaporator is too cold. This could be because of a low refrigerant charge
Jun 04, 2013 | Fujitsu ASU7RLF HFI Wall Mounted Mini...
WATER LEAKING FROM GOODMAN UNIT, NO AIR COMING OUT
! shut it down but leave the indoor fan on. check the filters and replace as needed. It also appears the drain is plugged or iced up. If ou can access the indoor coil you can service the drain and run some hot water thru the pan that catches the condensate. If you can see your indoor coil and you see a "lint blanket" on the indoor coil you will have to vacume it off as well. I hope this helps let me know Jon
Aug 05, 2011 | Goodman CLQ36AR49 Air Conditioner
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
There is water coming out of my indoor unit. So much water that I had to shut off the ac unit. It is a Mitsubishi Mr Slim split type air conditioner/heating unit
water coming out of an a/c is normal .its water outlet hose is wrongly installed or not installed at all.get it installed.also level the indoor unit towards the water outlet side when u install the hose .
Aug 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Water coming from indoor unit
The problem is caused by fine particulants such as dust, pet dander, etc. which mix with the collected condinsation water and forms a grey gel eventually clogging up the drainage pipe. The solution is to attach a wet vaccuum hose to the discharge end of the drainage pipe and vaccuum out the gel. It is advisable to flush the system by adding water to the a/c's drain pan while the vaccuum is still running.
Oct 07, 2009 | Mitsubishi Heating & Cooling
Control unit not working - blinking
i dont really understand, but if it a residential split and you have water in the emergancy pan underneath the indoor unit there is a float switch in that pan that is open not letting the unit come on it is there to prevent water from leaking throgh the ceiling.
drain that pan and unit should come on however something is wrong. when is the last time yuo changed the filter 9 times out of ten that is the problem if filter is changed and indoor motor not running that will cause unit tice up causing leak, third the which is unl,ikely you have a leak. if i can help you anymore please let me know
Sep 15, 2009 | Heating & Cooling
I have a samsung 1300 btu,theres a stinky stale water damp smell comin from the air an i noticed that the air conditioner does leak that much water,where is it goin
verify that the drain coming out of the back of the unit is clear, and make sure that the unit is pitched downhill to the outside, you can safely spray some bleach water in a spray bottle on the front of the indoor coil, that will ehlp with the smell after you get the drain cleaned,( you may also have some build up on the indoor coil. I would take the unit outside and thoroughly wash it.
Jul 11, 2009 | Samsung Heating & Cooling
Leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Sep 04, 2007 | Friedrich QuietMaster RS10J10 Air...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
