Question about GE (PSS26MSRSS) Side by Side Refrigerator
My compresser is not running - GE (PSS26MSRSS) Side by Side Refrigerator
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
1993 nissan quest wont start after over heating
Overheating will damage the head gasket and the cylinder head.
Insufficient compression in the cylinders due to leaks and the engine will not start. To begin with run a compression check on all cylinders and then any cylinder with compression not at spec run a leak down test to see where the compression loss is going.
Jun 27, 2016 | Nissan Cars & Trucks
My seat Ibiza s 1.4 cut out in the wet ain't started since iv been told there is no compression wen I'm turning the key its like it ain't catching
vehicles need three things to run. Spark / Fuel / and Compression. If it's true that there is no compression, the engine will not start. Run a compression test and verify there is compression. This is always the first thing you should do when diagnosing why an engine wont start.Good luck and most of all have fun and don't give up
Nov 02, 2015 | Seat Cars & Trucks
What should the compression be running on all cylinders.
check the compression in all cylinders with all spark plugs out the numbers should be within 8psi of each other
Mar 29, 2015 | Boating
WHY DO I HAVE NO COMPRESSION WHEN PULLING THE PULL CORD
Yes, you squirt oil into the cylinders and then re-run compression test. If the compression comes up then the rings are bad. If not it is in the valves. A variation of 5 lbs. between cylinders indicates burned or stuck valves.
Aug 29, 2014 | Motorcycles
What is the Compression supposed to be for a 1987 Toyota Pick up 22R with carb, 4 cyl.???
A new engine would be about 180 psi for each cylinder. As the miles add up and wear occurs, compression will get lower. The important thing is that compression is even and balanced-lowest compression reading should be within 75% of the highest cylinder's compression. Some Toyota engines had a minimum allowable compression of about 135 psi, but if compression is balanced, you could have average compression as low as 125 psi and engine would still run good, some loss of power but still acceptable, and oil consumption would not be that bad.
If cylinder compression is below 120 psi as an average, you should be looking into a rebuild event-rings and valves need attention. If any cylinder is below 100 psi, it may not even fire, certainly will produce no power, and could be a head gasket failure, very worn rings, or valve problems.
Remember the important thing is to find compression readings that are very close to each other. I have an '87 Sentra with 75,000 miles(true!)-lowest comp. is 160, highest is 165 psi-runs great, good power. Also a '79 Datsun pickup (with god only knows how many miles-about 200,000 maybe). Compression is about 125-135 psi, fairly well balanced-noticeable loss of power, very little oil burning, still runs fair to good-dependable, at least.
That should give you an idea of what to look for. Good luck.
Aug 29, 2013 | 1987 Toyota Pickup
My Frigidaire Model # FRS26LF7DS7 is not cooling!
Could be a few problems. What I would do is check to see if the compresser is running by pulling out the fridge and pulling the back panel off and putting your hand on the compresser. If it Is vibrating then it is running. If it is not vibrating but very hot then the compresser is dead and needs to be replaced. If the compresser Is cool and not running I would say the thermostat inside the fridge is dead(bad contacts in the control). If the compresser is running but no cooling, the cap tube which is the metering device for the refrigerant into the freezer evaperator could be plugged off. Or if none of the lines off of the compresser are hot or cold then the valves inside the compresser are gone and compresser needs to be replaced hope this helps
Sep 06, 2012 | Frigidaire FFHT1817L Top Freezer...
I have an xr250r 1996 but wen i kick start it thers no compression but can run start it sweet and theres heaps of compression how can i fix this problem
First , check your compression with a compression tester. It should be at least 100 pounds pressure just to run. Preferably 120,130,140,etc.. Some motorcycles have a decompression cable that works off the kick lever, others have a decompression lever you hand operate. I believe yours is hand operated . I think the actual lever in the valve cover on top of the motor is sticking or the decompression cable itself is hanging up and not allowing the exhaust valve to close properly.
Oct 01, 2010 | 1999 Honda XR 250 R
Car running on 3 cylinders, changed spark plugs but still running rough
Do a compression check. You want to check and see if you have good compression across all cylinders or if you've blown you head gasket or rings. If you don't have any check engine light indicating a faulty crank position sensor, or a misfire on a cylinder, you may have fire on the cylinder but if there is no compression or low compression the vehicle will run roughly. If you need directions for doing the compression check or manually checking the Crank position sensor and other sensors that could cause this condition I recommend the Haynes Repair manual on your vehicle. Most major Auto Parts stores carry both Haynes and Chilton's manuals on vehicle. I prefer Haynes but Chilton's will do as well.
Aug 02, 2010 | 2000 Ford Focus
Dead cylinder. good spark (plug&wires),compression,fuel .Has an engle 110 cam and comp elec. points.Every thing else is stock,duel carb set up 40 cadron solix.
Vacuum leak? You said compression is good. You checked crankning compression, did you check running compression. A broken valve spring would cause good cranking compression but very low running compression
Apr 24, 2010 | Volkswagen Beetle Cars & Trucks
GE (PSS26MSRSS) Side by Side Refrigerator Logo
19 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
