Question about Mitsubishi WD-60735 Projection Television
Changed the bulb on my mitsubishi wd60735, it worked for 2 days then just stopped working. the lamp doesn't even turn on, there is sound, was wondering if there is anything i could do at home to maybe fix the issue. the lamp appears to be fine and not blown again.
    New Friend:
  • 74 Answers
If the sound is a "crackling" or "buzzing" sound then chances are you got a defective lamp. Pull out the new lamp and inspect it.
Posted on Aug 27, 2010
  • bgtte420 Aug 27, 2010
    no sounds from the bulb at all.
Mitsubishi WD60735. Had white spots. Later lamp went. Replaced DLP Chip and lamp. Screen lights up very slightly. No sound. Green LED light is steady. Projection lamp is on. What is my problem.
Check and replace the lamp inverter too. Lamp replacement should always accompanied by the inverter too. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Feb 01, 2017 | Mitsubishi WD60735
Dark screen on my wd60735 Mitsubishi big screen TV but here sound very good what the problem?
Hi Jomo, sounds like your TV lamp is not working and needs replacement. You can buy the replacement online as well. It's quite popular. Good luck!
Dec 13, 2014 | Televison & Video
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
Mitsubishi wd60735 error code 66
No such error code that I can find, try to unplug and let it fail again, then do the check again.
Dec 23, 2012 | Mitsubishi WD-60735 Projection Television
Mitsubishi wd60735 code 37
A 37 error code means one of your fans is bad. It would either be the DMD fan, or the lamp fan. Take the back cover off of the set and tape down your lamp safty switch. Turn the TV on and see which fan is not working, and replace.
May 17, 2012 | Mitsubishi WD-52525 52" Rear Projection...
I have a 65 inch DLP and when i turn it on i get no picture and just the sound of static comming out of the front tv speaker, no actual audio from the cable box. When looking near the bulb box i see the...
When was the last time u change the projection lamp?If u watches tv at lest 4 or 5 hours a day and the projection lamp has not been change the last 1 1/2 or 2 years.This problems happen alot,when the projection lamp life is over.Change the projection lamp.
Sep 03, 2010 | Mitsubishi WD-65731 65" HDTV
Mitsubishi WD-60735 Projection Television Logo
101 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
