Cant download drives, dont have the directXfiles props on my system yet
  • 319 Answers
<span class="f"><cite>https://www.microsoft.com/windowsxp/using/.../russel_x64faq.mspx</cite> </span>
Posted on Aug 27, 2010
Cant get forward gear,
check the rubber bushing in the prop as it tears when the prop is jammed
if there is no rubber bush there will be a shear pin in the shaft that will be broken
Jun 12, 2015 | Boating
Cant locate four wheel drive on off switch
sound like you have the automatic four wheel drive system where the transfercase control module controls the 4WD system if you dont see shifter knob on console you have automatic 4WD drive system.
Jan 17, 2013 | 1998 Mercury Mountaineer
Have 2007 yamaha 115 saltwater series, just bought, planned once and then didnt plane, was told its prop bush slipping, can you explain?
The splined hub on the prop is not solid , there is a rubber or plastic sacrificial piece between the outer and inner portions of the hub. Designed to slip if you hit rocks or run over a rope so you dont ruin your drive or motor, just a prop.
Sep 03, 2012 | Clymer Marine Maintenance and Repair...
My notebook toshiba q10 n250, dont have backup and or Any operating system ( after a format) so i tryed to install windows xp via an usb bootable, but now the bios dont recognize the hard disk (maybe...
You need the install program from Toshiba and should be able to download it from the Toshiba site. The drivers, OS and programs were most likely on the D:\ drive, before it got formatted.
Jun 04, 2011 | Computers & Internet
When I plug my seagate free agent go portable hard drive (250 gig) into my usb, it register's that there is a device pluged into the computer (give's me the DING, that window's is famous for) but say's it...
try a different usb drive. if you are using win 7 or vista uninstall that device driver you downloaded. if its xp re install your usb drivers from the windows site just go to your device manager
win 7 vista click on computer sys prop device manager see if drive is connected hit update driver or roll back. same with usb system on win xp right click my comp. go to prop, then device manager let me know if this helps. but really important to make sure that you are plugged into a usb port in the back of the pc not thru a hub
Mar 16, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I cant use my Seagate Barracuda 7200.7 80 Gb st 380011A, becase i dont have its driver,can you please send me its driver?
You will have to go to the Seagate website and download the drivers from there for it for your operating system.
Dec 27, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
1973 chrysler outboard 12.9. does it have a shear pin?
If you can't see a shear pin,it most likely will have a rubber bush in the prop hub that superceded shear pins.I am not 100% sure on your motor but that is what all motors have today.The bush is inside the hub of the prop and with the prop off,you cant see it.If the motor revs up when in gear,and you are getting no drive,this is the problem.Hope this helps
Jun 18, 2010 | Boating
Apache havoc micro... can not trim the helicopter it spins counterclockwise.
the cause of this issue is hair or something preventing the tail rotor to spin properly.. i had this issue and checked mine over very good, noticed the hair in tail rotor, and then took a needle to fish IT ALL out.. if u dont get it all.. it wont trim properly cause it cant spin fast enough
Mar 02, 2010 | Air Hogs Havoc Heli Helicopters
How to fit hardie spliser to prop shaft
They need to be driven out. Put the driveshaft on the ground with a socket slightly larger than the cup in the hardy splicer under it. Then get a punch as near to the size of the cup as you can. Drive down the top cup with a hammer which will push out the other out. Do this with all four. When replacing be carefull with the needle bearings they dont come out of the new cup's.
Oct 27, 2009 | 1999 Isuzu Trooper
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
