Question about Cycling
I have a Trek Bike Computer from the early 90's and the battery needs to be replaced. How can I get the code to program the tire size in?
    Genius:
  • 1,788 Answers
Go to a Trek dealer and he may be able to help you. Sometimes we have a copy of the instructions laying around or one of our mechanics will remember the instructions. Batteries can be bought at Radio Shack, their batteries will be fresher than ours because we do not sell enough of them.
Posted on Sep 10, 2010
Hello i have bought new tyres and the rear tyre is a different profile it should be an 130 /80 /17 and the rear tyre arrived as a 130/90 /17. Will the 90 be ok on the bike thanks for your reply
Hi, Caroline the 90 should be ok it is a taller profile which may affect your speedometer accuracy by 10% it will also decrease your cruising RPM slightly which adds longevity to your engine life. Depending on the year-make-model of your bike the speedometer may be recalibrated to compensate the difference..
For this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Tire Sizes Explained Dennis Kirk Inc
Motorcycle Tire Guide 101 and FAQ
How to Read Motorcycle Tire Sizes
Apr 06, 2017 | Motorcycles
How to Replace a Blown Bike Tire Inner Tube?
unbolt wheel and using tire spoons or the handle of flat ware [as long as its strong enough to not bend ]place inbetween the tire bead and rim and pry up and over rim now either use another to pry again next to spoon or slide spoon under and slide around rim removing tire reach in and remove tube check inner tire for debris fix or replace tube install
How to change and fix flat bike tire Trek Bicycle How to Fix Flat Bike Tire
Oct 20, 2016 | Cycling
How do I replace a brake pad on this bike. It's old bike, late 80's and early 90's. The bike is in good condition, needs cleaning, frame in good condition, but trying figure out to replace...
If it is a U-brake or V-brake all you need is an allen wrench is a special "L" shaped six-sided wrench, coming in various sizes, that fits into a recessed hexagonal socket hole in the end of an allen wrench.
Jun 29, 2011 | Cycling
Hi, I owned a 2011 Trek 7.6FX. So far the bike has been good and in stock condition but I was wondering: 1. If I could use a fatter tires like LT2 or LT3 if I were to hit the track. The 700x28c...
"Track"??? Do you mean "trail", as in REAL off-road rocks-n-roots singletrack?
Ah, the 'compromise' bike dilemma. This is NOT a mountain bike frame nor are the wheels designed for hard hits. But you could try to make it work for light-duty trails.
http://en.wikipedia.org/wiki/Bicycle_wheel
1. They make all kinds of rubber for 29ers which use the same rim size. Search for 29er tires.
The frame and fork may limit how large a tire will have clearance. Being totally stiff (unsuspended) the off-road ride would be rough by today's MTB standards. Think: loose fillings and blurred vision, plus a lot of standing to survive the ride. That takes energy. But then there are those who have intentionally bought 'niners without suspension for some reason.
A REAL mountain bike would be a better choice, just as a REAL road bike might be for that activity if sustained speed is ever a going to be a goal.
2. Avid's make good brakes AND levers. Which end is the problem, I wonder. Pads also play a major part in stopping power.
May 27, 2011 | Trek 7.6 FX WSD
I let a friend borrow my bike and he had a new tire put on back it is a 170/80-15 and now the tire rubs the stabilizer bar and if you adjust it off the bar then it rubs the chain is this tire bigger than...
It is clear that your new tire is bigger than previous one. You have now 17 cm wide tire but previously 15 cm wide. This is why the new tire rub your stabilizer bars. You can use additional spacer on bearing shaft actually, but this is not a good idea as it will give impact on bike instability. I suggest to replace the tire with previous one. This is the best for your bike.
Remember that tire with data 170 / 80 - 15 mean: - 170mm ( 17 cm ) tire width - 80 ( %) width to height comparison - 15 ( inch) wheel diameter
Warm regards, please vote if helpful, Jay
Mar 11, 2011 | 2001 Suzuki VZ 800 Marauder
Hi can anyone tell me what size my front tire is on my 1981 yamaha xj650
The size should be on the side of the tire. If memory serves me correctly The bike came with a 3.25 x19 (100/90x19). If your speedometer is reading higher (faster) than it should with a 100/90/19 you can bring the high reading down by trying a 3.50 x 19 (110/90 x 19).
Feb 25, 2011 | 1981 Yamaha XJ 650
Just need to know the oem recommended tire size front ant rear for this bike.
The recommended tire size for the Suzuki VL 800 is:
FRONT: 130/90-16
REAR: 170/80-15
Feb 18, 2011 | 2003 Suzuki VL 800 Volusia
What is the size of the fron tire on this bike.
1992-1999 Suzuki VS800 intruder:
Front tire
80/90-21 or 80/90H-21
Rear tire
140/90-15 or 140/90H-15
H rating indicates rated for high speed.
Sep 02, 2010 | 1993 Suzuki VS 800 Intruder
What size tires come stock on this bike
41009 SKU: 41009-0001
TIRE,FR,90/90-21 54S,K750(D) 1 $43.96 partsadd.gif 41009A SKU: 41009-0002
TIRE,RR,130/80-17 65S,K750(D) 1 $50.83 These are your tire sizes. Chaz Moto Dc
Feb 25, 2010 | 2007 kawasaki KLR 650
Tire replacement
but whats the widest size tire I can safely mount on the stock rims. Have seen it posted somewhere that I could mount a 4.10/19 on these. That would probably smooth out the ride a little bit. But just wondering if it would start clearance issues. When you need a wider tire you really need a better tire. Try the Avon AM26. Rear 100/90-19. Front 90/90-19. These will transform your bike.,
Nov 10, 2008 | 2005 Enfield Bullet Sixty-5
Cycling Logo
183 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
