Question about Singer 3116 Simple
The bobbin in my 401A jamsafter sewing only a few inches leaving a knotted "mess" on the fabric . How can I repair this?
    Genius:
  • 1,788 Answers
Something is not threaded right on the top, or the thread is tangled. Take the thread completely out and rethread. Also, make sure that no thread is caught in the bobbin area, if necessary take bobbin casing out and clean with a brush. Always turn the handwheel towards you, never away from you because it can mess up the timing, Also google Singer 401a there is a great blog on this machine
Posted on Aug 27, 2010
How do I fix the tension - it is too loose and knots up after a few inches
The tension disc is turned to the right to tighten, if the stitch on the top of fabric is loose then the bobbin is your problem
Mar 07, 2015 | Sewing Machines
Thread tension
BOBBIN TENSION: BOB THE BOBBIN CARRIER AND BOBBIN WHILE ADJUSTING TENSION. WHEN IT WILL EXTEND ONE INCH IT IS RIGHT.
TOP TENSION: USUALLY A GOOD STARTING POINT IS THREE. THE TENSION IS RIGHT WHEN THE KNOT IS FORMED IN THE CENTER OF THE FABRIC.
TOP TOO TIGHT: WILL PULL EXCESS AMOUNT OF BOBBIN THREAD UP THROUGH THE FABRIC.
TOP TOO LOOSE: THE BOTTOM OF FABRIC WILL HAVE EXCESS AMOUNTS OF THREAD. USUALLY A MESS OF THREAD.
Dec 27, 2014 | Sewing Machines
Set the tension
set the bobbin by allowing it to hang from your finger while the thread goes under the tension. it should ride down the thread one inch when you bob it lightly. now, when this is done replace the bobbin. now, the objective is to get the top tension to equal the bobbin tension so the knot will go to the center of the fabric. this can start at a setting of three and be adjusted as necessary. the main objective is a tug of war between the top and the bottom so the knot will go to the center of the fabric.
Nov 16, 2014 | Sewing Machines
Cant get my bobbin in right position it keeps knotting up on inside of fabric
Top thread problem, Not enough tension on top=loops on the bottom of the fabric; too little tension on the bottom = loops on top of the fabric. Yes, I know it seems backwards. See: http://www.picturetrail.com/sfx/album/view/22521551
Dollars to donut holes, you either threaded the top of the machine with the presser foot down (it has to be UP to let the thread into the top tension), or you're trying to sew with the presser foot still up (which is an issue common to people trying to sew bulky seams).
Take the thread off the top of the machine, take out the bobbin case and give the machine a cleaning, rethread the machine, fetch up the bobbin thread and hold the bobbin and top thread ends together under and behind the presser foot for the first 2-3 stitches of each seam.
Jan 26, 2014 | Brother LS-2125 Mechanical Sewing Machine
I have a Bernina Deco 330, I am having issues with the Bobbin thread coming through on top of design. It is also tieing the knot in top of the fabric. The design will be flipped, the smooth side on back of...
A few things to check. Is the upper thread caught? You can test the upper tension, that could be pulling up the bobbin thread, by putting a size 80 needle in the machine. Put the presser foot down and pull on the upper thread it should bend the needle about an 1/8 inch when the tension is at 5. Also check the threading is done correctly and not catching on a thread guide.
Sep 02, 2013 | Sewing Machines
Needle thread knots up under fabric.
I have the same problem but i have not watched it. I does not seem that anyone wants to help us here, I am going to other sites until i find someone knowledgeable. apparently we are the smartest here at the moment ;)
Mar 31, 2013 | Sewing Machines
Thread mess at the underside of the fabric
On the bobbin holder there is a smaal screw, thghten the screw to set tention on the bobbin thred. The thred you use on top and in the bobbin can be the problem as well E-Mail me wcbotha@yahoo.com
May 10, 2010 | Singer 8280 Mechanical Sewing Machine
Bobbin Thread is "birdnesting"
Get out the manual and refer to the maintenance section for cleaning the machine.
Especially the bobbin area. You want to make sure the area around the bobbin case is free of lint and thread.
Use a new bobbin and re-thread the machine, with the presser foot UP.
Install a new needle, again according to the directions in the manual. Installed incorrectly can lead to mis-stitching.
If the problem persits, the timing may need adjusting.
This should be done by the sewing machine tech for Kenmore.
Sewusa.com has a guide for this in the repair section, but you could end up with more problems.
Apr 29, 2010 | Kenmore 15202 Mechanical Sewing Machine
Bernette sewing machine making a mess of thread on back of fabric
I once heard from a great sewing instructor that if the problem is on the back of the fabric then it is a spool to needle problem.... if the problem is on the top of the fabric, then it is a bobbin problem. Check your machine for dust and stray threads. Check your bobbin casing for dust and stray threads.
Dec 14, 2008 | Sewing Machines
Singer 3116 Simple Logo
299 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
