Question about Microsoft Windows XP Home Edition
Keyboard locked in upper case
Hi ann my keyboard is stuck in upper or lower case too did you solve your problem can you tell me how to fix mine? microsoft keyboard and gateway computer do you know where function key is on the keybaord someone suggested holding down function key and press f11 don't know where to find your response to me... judi
  • Judi McInnes May 10, 2008
    Thanks - that's all helpful information. I was able to resolve it by removing the keyboard option for sticky keys - settings - remove check mark - apply. Apparently, you may also resolve this problem with the keyboard stuck in upper case by holding down two keys at the same time, but I resolved it before I could try that. A frustrating problem no more... Thanks.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
Try reseating the key board.
Check whether the keys are stuck especially the shift,alt,caps lock.
Hav you spilled any liquid on the keyboad.
Try uninstalling any software you installed for the keyboard and remove it from Device Manager (Click Start-Run-Type devmgmt.msc and click OK).
Reboot and see if that helps anything. Also, check the right shift and make sure it isn't stuck and check the keyboard settings in the Control Panel
Update the keyboad software from the microsoft website.
Pleae mntion the model  number of the keyboard to help us know more about the keyboard.
You can try holding down function key and press f11.
Control Panel -> Regional and language settings -> Tab: Languages,
Button: Details, and add a US Keyboard.
Check this to know the functions
http://support.microsoft.com/default.aspx?scid=kb%3ben-us%3b894513
Check the keyboard settings.
Try using other keyboard to know the keyboard is fine or not.
This will help you i hope.
Good Luck.
Live, Love, Laugh.
Posted on May 10, 2008
My Wi-Fi authentication problem. 2wgp2 put in pass word. I tried direct connect can't get it to authenticate. This is my first iPad and I am not a tech savvy person. What do I do.
Ann, make sure you are using the same type of authentication on both devices. Second, ensure they are both the proper upper and lower case, as they are case sensitive. It might have a caps lock on or a num lock on, depending on keyboard configuration... Let us know what's up..
Jul 10, 2014 | Cell Phones
Is there supposed to be a caps lock indicator on HPw2207 keyboard,? If there is, I must be missing something I can never tell if I am in upper or lower case letters ( not too good when entering a password)
That model goes to a LCD monitor, not keyboard. Windows can make a tone when you hit the cap locks, so you can use that as indicator or you can use the on-screen keyboard which should visually show the cap locks being pressed.
How to tell when you hit the cap locks key
Windows On-screen keyboard
Mar 25, 2011 | Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
WHEN YOU PRESS THE CAPS LOCK BUTTON YOU HAVE THE CHOICE OF UPPER AND LOWER CASE LETTERING BUT THERE IS ALSO AN ARROW BUTTON WHICH IS TURNED OFF AND I AM NOT ABLE TO TURN IT OFF IT SEEMS TO HAVE REVERSED MY...
That UP arrow refers to an UPPER CASE letter. If ever you press the CAPS LOCK key, it should turn off, if it does not it means the CAPS LOCK key for some reason is stuck. Try restarting the computer and by then the CAPS LOCK should be disabled.
Please let me know if it helped by selecting YES. Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Jan 31, 2011 | Gateway 2520915 Keyboard
Cap lock is stuck on-- I need to use lower case to
Anyways, you can use the shift key to convert the password characters in lower case.
All you need to do is to press shift+your password.
Remember that you need to hold the shift key down while pressing all other keys to write in lower case.
Also, with your keyboard you may need to get help from a local repair.
Please do tell us that you have the problem fixed.
We are always available for your help.
Regards.
Jul 19, 2010 | Microsoft Windows XP Home Edition
I can not get lower case
Check for a light on the keyboard, caps lock could be on.
The caps lock key might be sticking press down on it a few times might loosen it a bit.
Jan 22, 2010 | Acer NSK8458AN Keyboard
Keyboard stuck in upper case
press caps lock and F9 together see if that fixes it
May 06, 2008 | Microsoft Windows XP Home Edition
Types in upper case only (without caps lock/shift key locked)
in most cases yes, BUT since the light for caps lock is not comming on you might have a bad P.O.T. on the keyboard layer.. Since im assuming we are talking about a laptop..
Mar 07, 2008 | Acer NSK8458AN Keyboard
Is the caps lock light illuminated? If so, you might have to hold shift and hit caps lock to turn off the caps lock. This is an option for old typists who came from manual typewriters that you might have turned on by mistake.
Mar 05, 2008 | Acer NSK8458AN Keyboard
Keyboard
Have you checked with another keyboard? at the moment there's no telling if the problem is with the keyboard or with the computer. If the problem is solved with another keyboard, and a driver update does you no good, I don't think it's worth your time and money. keyboards come cheap these days. Good luck
May 13, 2006 | Micro Innovations (09N5540) Keyboard
Microsoft Windows XP Home Edition Logo
871 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
