Question about Kodak EasyShare C340 Digital Camera
The camera turns on and the lens does not extend and the camera shuts off
  • 10,515 Answers
I am Sorry to hear regarding the Problem.This is a ' Lens Problem ' which is Quite Common on these Models.
It is not worth to get it Repaired, as the Cost of repair would be quite high as compared to the cost of the new camera.
There are a number of things you can try:
1. Ensure batteries are fully charged
2. Look carefully between the lens and the camera body for any sand or other dirt etc
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 2 minutes and refit
If no luck then we have to try some things that could possibly result in damaging your camera so should only be tried if happy to take that risk...
5. Try thumping the camera into your other hand, by thumping into your hand you are trying to jar the mechanism loose, by using your hand you will hopefully not do it too hard or it will hurt. You may need to do this a dozen or so times in different places to work. I have found the flat of the camera bottom into the flat of your hand best..
6. If the lens is stuck in the out position then remove the batteries and try twisting the lens first one way then the other, do not apply excessive force when doing this or you can break gears, you are trying to reposition not force... Likewise if the lens looks like it is crooked you can try pushing it back into position. This has a higher chance of doing more harm than the thump so please be careful...
7. Dismantle the camera, not for the faint hearted, you need to dismantle the lens assembly into the main body of the camera
If no luck then only other option is a serviceman I'm afraid, be sure to get a quotes as camera repairs can be uneconomical
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 27, 2010
The camera turns on then shuts back off again
hat type of problem is usually associated with a lens extend error.
It is usually caused by weak batteries or dropping the camera.
Keep your eye on the LCD screen when you turn the camera on.
Do you see any type of error message?
Now turn the camera on again and help the lens extend by gently pulling on the lens as it extends.
Does the camera stay on when you do that?
Sep 24, 2010 | Kodak EasyShare Z740 Digital Camera
Lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 28, 2010 | Canon Powershot A1000IS Digital Camera
Y Canon Power Shot SD400 digital Elph camera won't shut down
Your problem in your lens...Try to bring service center. Cause, canon lens it for me it not easy to disassembe dan assemble it again...Different with other camera lens, like KODAK and Samsung.
At sony camera "E18" can be "Turn the power off and On again" like my Sony W.35
Aug 22, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Camera turns on and then shuts down leaving the
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 13, 2009 | Sanyo Vpc-s1070w Digital Camera
My kodak easy share M1063 turns on then shuts right off how do i
I had the same exact problem. When the camera turns on and then lens extends, hold the lens out while the camera shuts off. Then sort of move it around a bit. I did this and when I turned it on, it was fixed. I guess something was jammed in the lens.
Jun 24, 2009 | Kodak EASYSHARE M1063 Digital Camera
Spring visible through the lens
Defective Lens Block.
Needs to be replaced.
Aug 15, 2008 | Pentax Optio 555 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Camera beeps 3 times the shuts off
I've decided to send the camera in for possible repair.
Feb 17, 2008 | Samsung S630 Digital Camera
Nikon L3 Lens wont extend
Hi:
If the camera has not been abused, such as dropping, impact of some sort, or restricting the extending lens, then there is an internal problem.
See my other posts on suggestions of selling it.
Nov 27, 2007 | Nikon COOLPIX L3 Digital Camera
Kodak EasyShare C340 Digital Camera Logo
21 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
