Question about Dometic RM2852 Refrigerator
I have an unused 4 year old dometic rc4000 portable refridgerator that was checked to be working when purchased but on trying to run on mains electric today does not appear to be working (no sound to indicate unit is working). Also tried to power up using 12 volt battery via car cigarette lighter and still no sign of unit working. Any ideas what could be the problem. Unit has been stored in an indoor cupboard for the last 4 years.
I HAVE THE SAME PROBLEM THOUGH I HAVE BEEN USING MINE FOR THE PAST 4 YEARS...ON INSPECTION ...REMOVED ALL THE PLASTIC COVER ABOUT 12 SCREWS,...FOUND A YELLOW POWER ON THE PIPES AND IT LOOKS LIKE THE COOLANT HAS LEAKED OUT????
SAVEABAT AT ADELPHIA DOT NET
SAVEABAT@ADELPHIA.NET
JOHN
Posted on Oct 12, 2010
I have a dometic refridgerator Rm3762 or Rm3962 one year old in my rv. It stopped cooling and is plugged in to 110. I was having problems on lp and restarted it a couple of times.
If your unit is working ongas,check your electric heater element locaged in the large round tube onthe righ handside when looking from the outside. You can check current draw , should be about 2.5 to 2.75 a/c amps. If electriccheck okand the gas is working, check for ayellow residue around the base of the refrigerator on the outside. Also if you have an amonia odor, this will indicate your cooling unit has leaked out and will have to be replaced. It could also be blocked which would cause loss of cooling. Hope this helps
Oct 09, 2011 | Dometic Rooftop RV Air Conditioner
I have a dometic mod.2852 refridgerator/freezer that was working fine until a day ago when it stopped getting cold in both parts. It has power. the space between the freezer and refridgerator is very warm....
Check this link to dometic recalls first and enter your model number and serial number. There may be a recall on that fridge.
http://67.238.126.140/recall.php
Jun 13, 2011 | Dometic RM2852 Refrigerator
Everything is frozen in the refer portion. The refridgerator is two years old.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Dometic RM2652 Refrigerator
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
I have an rca L42WD22YX5 that just went to a blank screen yesterday. The screen keeps reading unusable signal. It is only 14 months old.
i had this happen last year, now my tv is messed up again. when we had the problem with the unusable signal, the tv repair shop told us it was the main motherboard that caused it. ended up paying $250.00 to have it fixed. Now, our tv is broke again, this morning turned it on, got the green light, then just started flashing red, hasnt worked any at all today, reset it and everything. My suggestion, if you can afford to buy a new tv, do it, because I called the repair shop again this morning about the new problem, they said after the 1 year warrentt from rca runs out all they do is tear up. My tv isnt even 4 years old, bought it at the end of 2007, now its tore up twice, going to purchase a samsung in the morning from brandsmart. Good Luck!
Sep 29, 2009 | RCA L42WD22 42 in. LCD Television
My dometic 2652 runs is not cooling on gas or electric .inside switching seems to function properly .heater is engaging. any suggestions?
Is there a yellow powder substance on the coils, heating tube or anywhere towards the bottom? If so, you have a leak. The best thing to do is:
1-Find a replacement unit online( ebay is a good place to start)
2-unhook electric line and gas line from the access panel
3-remove the refrigerator from the inside and place doors down(its heavy and you will probably need another person to help)
4-remove cooling unit from back of refridgerator
5-make sure you have enough thermo-mastik for the unit/coil contacts
6-replace cooling unit and hook up everything in reverse
7-turn on and let it cool for a few hours. My unit stays below 32F and works great.
Found the first one listed on ebay just now for $399.00 with a five (5) year warranty.
Mar 06, 2009 | Dometic RM2652 Refrigerator
Dometic RM2852 Refrigerator Logo
411 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
