Question about Toshiba 43HX70 43" Rear Projection Television
Toshiba back projector 43' how do i make the av
Toshiba back projector 43' how do i make the av work? i connect it 2 dvd but have no idea how 2 swich 2 av in the tv
    New Friend:
  • 74 Answers
Look at what input you plugged the DVD player into. maybe AV1 or AV2
Now on your remote, or on the front of the TV, push input until it stops on the one that your DVD player is plugged into.
Posted on Aug 27, 2010
  • inbarbee Aug 28, 2010
    tnx dear... but there is no input 2 push, not on the tv or the remote.. i did plug the dvd 2 av1..
    any other idea?
    please...
Dvd play works but vcr playing does not
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
May 05, 2010 | Toshiba SDV395 DVD Player/VCR
I have a toshiba D-VR610KU combo. Cannot get the
ACCORDING TO THE TECH AT TOSHIBA: THE UNIT MUST BE CONNECTED TO THE TV BY AN HDMI CABLE FOR THE DVD PART & (ON THE BACK-RIGHT HAND SIDE OF THE COMBO) YOU NEED TO CONNECT A SET OF THE RED/WHITE/YELLOW CABLES FROM (VIDEO) "OUT" OF THE COMBO & "IN" TO THE RED/WHITE/YELLOW TV(AV-1) PORTS FOR THE VCR PART TO WORK.
Oct 15, 2009 | Toshiba D-VR600
I cant play my dvd on my infocus LP280 projector
Please provide us with more details like the DVD player make/model and what is the connection cable you are using.
Normally, you should be able to connect the DVD player through the AV out pins and connnect it to AV in of the projector.
Other options that can be used are:
S-Video connector, component video connectors, and DVI-D connections
Please reply for more help and clarifications. Thanks.
Aug 05, 2009 | InFocus Office Equipment & Supplies
Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Jun 01, 2008 | Onkyo TX-SR702 Receiver
Suround sound
Hi mich11
Right firstly you will have to check how many inputs you have on your Projector and then also how many inputs you've got and then work from there.
Typically it would be like this :
1.) S-Video cable running from your DVD player to your Projector. S-video - S-video points - both males.
2.) RG59 ( video cable ) running from your sky/satelite decoder to your Projector - once again 2 RCA points - both male.
I'll quickly browse through some of our installation pics and post you a couple.
May 05, 2008 | Toshiba TDP-S20U Multimedia Projector
57H82-no picture from DVD input
How does line out from the DVD player do? I would suspect a bad preamp/buffer on the TV...accordianman
Mar 17, 2008 | Toshiba 57H82 57" Rear Projection...
How to access AV channel on Toshiba TV model 2125RA
some sets auto-go av when you plug a rca jackin the set, others have a switch in front or back , others you might set your channel to 00 or 99 or 100 forget and work different , I the owners manual of course would tell you. but I assume u dont have it . try hooking it and letting the dvd run now find it using the remote.
good luck.
Feb 23, 2008 | Televison & Video
No HDMI video signal to projector
cheak out put on samsung to set it at 720 hdmi out ect might nee dto use red green blue or s video to see menu
Feb 05, 2008 | Samsung DVD-VR357
RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Aug 23, 2007 | Rio Go Video DDV9475 Dual Deck VCR
Toshiba 43HX70 43" Rear Projection Television Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
