Question about ASUS Computers & Internet
ASUS E3110 Laptop will not boot up, it keeps recycling onto the 1st screen
  • 319 Answers
<span class="f"><cite><span class="bc">www.xtremesystems.org &rsaquo; ... &rsaquo; <a rel='nofollow' href="http://www.google.com.pk/url?q=http://www.xtremesystems.org/forums/forumdisplay.php%3Ff%3D61&amp;sa=X&amp;ei=7jJ4TOSmNIXJcYHnuIsG&amp;ved=0CB4Q6QUoAQ&amp;usg=AFQjCNGvxlBWr7yrum5jIRdnQ4PJi69mJg">Hardware</a> &rsaquo; <a rel='nofollow' href="http://www.google.com.pk/url?q=http://www.xtremesystems.org/forums/forumdisplay.php%3Ff%3D59&amp;sa=X&amp;ei=7jJ4TOSmNIXJcYHnuIsG&amp;ved=0CB8Q6QUoAg&amp;usg=AFQjCNHYPc09TTKQZyanVo6Mqse27lxfoA">Inte</a></span></cite></span>
Posted on Aug 27, 2010
Screen won't come on my asus laptop.
Laptop screen won't turn on, but works with external monitor ...
www.tomsguide.com/.../laptop-screen-turn-works-external-monitor.html
Oct 16, 2015 - Hello, my laptop screen won't display anything. It boots up and ... External Monitor; Function Keys; Laptop Screen; Windows 8; Asus. Display.
ASUS laptop screen won't display anything - Tom's Guide
www.tomsguide.com/answers/id.../asus-laptop-screen-display.html
Aug 28, 2013 - My laptop screen won't display anything Forum; Asus n56vz laptopwont ... i cant remove the asus battery to my laptop and the screen wont turn ...
Asus laptop black screen problem - YouTube
? 7:52
https://www.youtube.com/watch?v=gRQgN5AT3a0
Aug 2, 2011 - Uploaded by mrwangyanfei
Black screen when switch on Asus laptop (N61J) ... I turn on mypc and the screen stays black. I tried ...
Dec 13, 2015 | ASUS Computers & Internet
Asus g50 has no boot mgr, and when i try to reload windows it wont recognize any hdd?
Try booting in safe mode first.
Start your PC and as soon as it starts, keep pressing the F8 key continuously. If a screen comes up with an option to start in safe mode, go to that option. If you can boot to that option, go to start-type in system and look for system restore. Click on that and follow the instructions.
If you can't do that then look here:
http://www.tomshardware.co.uk/faq/id-1945283/tutorial-fix-bootmgr-missing-error.html
Dec 10, 2014 | ASUS Computers & Internet
Asus....I can't get onto anything no options. Bsod. How do I get to reboot screen.
if you have a restore disk turn off your laptop and boot the cd /usb key via bootup screen normally f12 key
Jun 11, 2014 | Computers & Internet
My ASUS Z99E laptop cannot access winXP
Try to access the BIOS "F2" Key, Go to the BOOT Section, set the 1st Boot device to DVD / CD Rom. Press "F10" Save and Exit. If it fails again, re-enter the BIOS. Then make sure the drive is set to IDE and not ACHI. press "F10" save and exit the BIOS. If that fails then select in the BIOS Load Setup Defaults, and re-select the boot device to DVD/ CD Rom.
If all fails, you have to open the side or bottom cover to remove the HDD - Hard Disk Drive, Connect it to a Stand alone pc via the SATA Cable or External Device (Works as USB) then you can either do an emergencey back-up, Format the drive through windows.
Hope it helps
Mar 23, 2014 | ASUS Z99E COMPATIBLE LAPTOP LCD SCREEN 141...
Pxe boot is it safe to remove from boot sequence
It goes to PXE, because it no longer sees the hard drive or OS. Boot into BIOS and verify hard drive exits. Go ahead and make it 1st boot.
If problems still exists, reseat or replace it.
Oct 12, 2012 | BenQ Computers & Internet
Asus k501 wont load says bootmgr missing
You would need to do a windows start up repair. Look up the F key needed to go into the factory restore manager should be F12 or F10 but when you 1st boot the pc up b4 or while in the ASUS splash screen look at the very bottom of screen it will tell you there which F key to hit.
Sep 17, 2012 | ASUS K501 Laptop 2.2GHz Intel Pentium...
Lap top will not boot need to know how to set the boot options in the bios
If you are interested in doing it more easily and quickly. I think you can try this computer boot up suite. When your computer crashes, cannot enter Windows, or you want to work under boot environment, this is your NO. 1 choice.
Jun 06, 2011 | ASUS Computers & Internet
Reboot and select proper boot device and press a key with black screen my laptop has no CD/DVD ROM
hi...
set up your bios with boot 1st harddisk...
if that appaer again..check your hard disk..
tht problems occur becous your hard disk not detact.
thnks&regards
Dec 10, 2010 | ASUS Eee PC 1000H Laptop
Netbook will not boot up ,keep getting blue screen saying could not boot up then goes back onto normal boot screen then goes onto black screen asking whether to boot up normally or in safe mode
you have a corrupted operating system, please restore the laptop by pressing Alt+F10 immediately after pressing the power button and follow the screen.
Hope this helps
Apr 06, 2010 | Acer Aspire One PC Notebook
Building new computer with ASUS M2A motherboard and AMD 749 processor. Computer starts, displays ASUS setup screen, goes to blank screen with blinking cursor and then hangs up.
Try to check connections to hard drive...If OK..then check boot device priority in BIOS and change 1st boot device as Hard drive..Then If not worked then chnage 1st boot device as cd rom and boot from a bootable CD and installl OS..
Dec 09, 2008 | Computers & Internet
Computers & Internet Logo
107 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
